furg69
Removed my clutch last night to inspect the rollers and bushings and check my weights(roller bushings were toast). I noticed the flat side of the drag n flys that roll on the rollers are alittle worn and indented. Im not sure if the kit is meant to have a slight indent on the roller side or not. Also i have a setup i am going to try that was giving to me by one of the best "Turk" and im wondering if anyone has tried on their XTX. Would love some feedback as i plan to get things back in shape before the snow flys. Thanks guys for any info.
use black HC spring
1 bolt 3 washers in arm
1 bolt in overdrive
centre empty
1 bolt 1 washer in tip
use black HC spring
1 bolt in overdrive
centre empty
shadow44
Turks black spring setup is awsome...even though I have an RTX I can say it's great. As far as the worn spots...Revster found the same thing, give him a pm and ask him what became of it.
My DNF's did the same thing. I called SuperTorquer up and explained the situation, they replaced the weights for free, I just had to buy a new set of bushings.
furg69
Just got off the phone with Randy at SuperTorquer. I have to say, one of the best to deal with. Excellent Service. He's resolved my issue with my weights for a very low cost (basically just the price of bushings). Hope to get them in time for the snow.
nytroman20
I have the same problem. Would anyone have their phone number?
