shadow44
I am running an 08 Nytro RTX with full mods, this year I changed to 22/38 gearing. I am running Turks Black spring set up and with the gear change I'm only pulling 8500 rpms. I know I have to remove some tip weight but my problem is I need to lose roughly 2grams ( being 1g is roughly 200 rpm ). I'm running 1 washer, one bolt in the tip....removing 1 washer barely got me 1g...the bolt is 3G....how much does the OD part of the weight help out with top rpm?
woodysattak
- Apr 15, 2010
- Union Grove WI
- 2017 RTX LE
- Waterford WI
drag n fly
Just go to a hardware store and get 1/2 inch set screw. Just weighed one and weighs 1.9 grams which would give you about a 2 gram weight reduction. Kurt
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
I went to fastenall and ordered some 1 /4" stainless button heads along with a selection of other sizes to fine tune with because the selection you get with the weights don't let you get where you want to be, to heavy
baggs66
- Nov 18, 2007
- 06 apex gt
