Drag'n'fly set up with KN's and PCV
Tyloooor
sudbury, ON
anyone have a good set up for Drag'n'fly with KN's and power commander?? currently running Turks set up but I'm still over revving....I've tried to add extra washers but can't get it nailed down
Turks black spring set up was done on a stock sled so it should be close the way he had it, what are you running for rpm? Also keep in mind that Turk also tested on a hard packed track. With his set up I was around 9050 rpms but have a full exhaust and airbox mod so I found that rpm perfect, however it would hit 9250 in powder or loos conditions.
on WOT pulls- i'm bouncing off limiter with the turk set up.....i've got it down to 9200 ish and climbing on hard pack to the limiter....I think it pulls the hardest at 8900 ish and would love to be there. I bought the KN's and PCV from ulmer with his map to run with excell header and stock exhaust.I think all stock last year my sled was faster on top end.....
I think I might get angles of the faces of my primary changed so my belt climbs all the way to the top....
You won't run a faster top end with Drag n flys, but you will get there faster. Stocks weights will pull better top end. Seems weird that you're bouncing off the rev limiter...I'm wondering if you can get a heavier bolt...only need about a bit more than a gran to get you there.
ya I was thinking the same thing....I do get there faster but I run out of legs...my buddy walked passed me yesterday with his 600 etec gade yesterday on WOT.....
