Tyloooor
Good Day
anyone have a good clutch set up for a drag'n'fly clutch kit??
can't seem to find Turks set up
Bought a used kit and install what the guy said "worked great" for him, but I'm over revving
thanks
thanks
try this
1 bolt 3 washers in arm
1 bolt in od
1 bolt 1 washer in tip
centre empty
run black hc spring
This was what Turk sent me and it works great!
1 bolt in od
centre empty
run black hc spring
Tyloooor
sweet thanks!
but I only have a red and white spring...
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Black spring is part of the recipe. I run the black HC with my 2-speeds and it's sweet.
Tyloooor
where do you get the black spring from???
canoehead
- Jan 14, 2011
- NE, Alberta
You can order one from Heel Clicker/Super Torquer and I believe Wahl Bros sell them. Put a ad in the WTB here, somebody might have one they want to part with. Good luck!
Tyloooor
Thanks.....
Tyloooor
anyone have a set up running the white or red primary spring?
yox185
Tyloooor
thanks....still trying to find a black spring, but i might try that this weekend.....just need to get my RPM's down....i almost hit my rev limiter (9300 ish) and then come back down to 9100 ish
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
Bender racing sell them.
This is the exact set up I ran in my Nytro with full excell exhaust, pcv, filters. Strait from TURK! God Rest His Soul.yox185 said:Straight from Turk
yamashaker
- Nov 12, 2010
- Candle Lake, SK.
- 2007 Attak GT / 2017 Sidewinder LTX
drag n fly clutching
Are you running a stock shorty Nytro? Do you have any exhaust mods or track or gear changes? are you using a power commander? What rpm's do you want to run if you have mods? What is your body weight when geared up? This info is is required to get the most out of the clutching
Tyloooor
well here's my info….
excell header, but otherwise stock exhuast
with my riding gear on…220lbs (but i think I'm 180)
stock 121 with a 1 1/4" track with 96 studs…
how many grams is a bolt??
MOUNTY
If Shaddow chimes in again, or PM him. I sent him a set up I had in mine when it was a pretty close set up as yours. I only used the red spring though. If I remember correctly, each gram in the arm lowers the rpm 100? Adding weight to the tip will work as well.
