Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
My sister in law ended up getting a leftover 07 Venture Lite this year. I knew previously that the drive belt is different than that of the other new Yammys.
I'd like to know how much are they different? are they interchangeable? Carlisle lists the same belt number for all the 4 strokes, so they can't be that far off, can they?
Isthatahemi
The Phazer belt is a softer compound, and I believe it is slightly shorter, (maybe longer), but the length is slightly different.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
8DN:
Top Width: 34.1mm (+/- 0.6)
Thickness: 16.0mm (+/- 0.8)
Angle: 28* (+/- 1)
Circumference: 1133mm (+/- 4)
8GS:
Angle: 28* (+/- 1)
Circumference: 1135mm (+/- 3)
Angle: 28* (+/- 1)
8GS:
Angle: 28* (+/- 1)
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I see the differences, but you marked them both as 8DNs.
With regards to the manufacturing tolerances (+ & -), they are the same size then, just different durometers, correct?
So the one for the Phazer is a softer compound ?? So worst case you could use a 8DN belt on a Phazer ??
Thanx
Bruce--
Thanx
Bruce--
- Apr 17, 2003
- Menno, SD
- Menno, SD
Fixed post above.
