codysRXwarrior
- Feb 11, 2015
- Brock, Ontario
- 2014 Viper Rtx Mcxpress Turbo
Lost the drive shaft bearing on clutch side of sled on my way home on my last ride. Bought a replacement kit and started removing the old one in pieces. And after removing the set screws the bearing what's left will not come off the shaft. Tried many different ways but had no luck.
Any tips for doing this while it's in the sled. I really don't wanna have to remove the driveshaft. That's a hell of a job.
Thanks everyone.
I'm starting to not enjoying fixing after every ride. Hopefully this is the last repair for a while.
Thanks everyone.
codysRXwarrior
- Feb 11, 2015
- Brock, Ontario
DoktorC
You can break the bearing race with a hammer and chisel...just be careful not to hurt the shaft and don't use a sledge hammer...if you hit it too hard you can hurt the chain case.
Try WD and a small punch in the set screw holes...try to spin it on the axle and loosen it up.
codysRXwarrior
- Feb 11, 2015
- Brock, Ontario
Unfortunately that's what I was trying. Tried each direction on each of the set screw holes and just taking a chisel to the remains of the bearing trying to free it up.
YammyRX1
You could try lots of penetrating oil over night and then heat. If you are worried about overheating the driveshaft you can wrap wet rags around it beside the bearing. If there is room you can try a cut-off wheel.
codysRXwarrior
- Feb 11, 2015
- Brock, Ontario
I was thinking heat but didn't want to risk damaging anything in there. But I'll let it soak then try heat. Thanks for the input.
03griz
Don't forget your best friend the air chisel........cuts stuff fast!
jong22250
Air cut off wheel or a dremal one cut on one side and one cut 180 off dont go all the way threw just most of the way then put ur chisle in thw groove and wack it it will split like butter flip it over and wack the other cut
straycat03rx1
- Aug 6, 2014
- t cats out the a$$ one rx1
Well if it were me id pull it apart and check all parts involved.Really.6 pack and your done.
blkhwkbob
I agree with Straycat.
codysRXwarrior
- Feb 11, 2015
- Brock, Ontario
Got the old bearing off with the Dremel and a chisel. Plus a couple days of penetrating oil. New bearing is in and made a strap to hold on the speedo sensor.
superfan75
Glad you got it fixed !! That looks like a simple mount for the sensor to.
codysRXwarrior
- Feb 11, 2015
- Brock, Ontario
Simple and efficient. Pretty much my middle name.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I would be concerned with the bearing in the lower chain case. If the drive shaft flopped around enough to wear into the tunnel as shown in your photos the lower chain case bearing definitely experienced loading it was not designed to experience. If that sled was in for service I would not send it out door without a new lower chain case bearing.
codysRXwarrior
- Feb 11, 2015
- Brock, Ontario
Sounds like a task for the off season.
