Tom Hearn
- Dec 31, 2016
- PEI
- 2010 nytro
I just swapped my track and found out the bolt that goes in the end of the driveshaft on the chaincase side was broke, got it drilled and all is good but would there be any harm in using this bolt, same length and thread just no smooth surface before the head... the bolt in refering to is #50
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
That bolt is known to break off. Its a pretty come problem. That bolt that you have will probably be fine. Really that bolt isn't even needed because all its used for is to hold the gears on the shaft for assembly of the chain case(makes assembly easier). There is a bearing in the cover of the chain case cover that holds the gears and reverse stuff in place.
Tom Hearn
- Dec 31, 2016
- PEI
- 2010 nytro
yah it was snapped when i disassembled and was told it looks like it was broke for awhile... thanks for the infoThat bolt is known to break off. Its a pretty come problem. That bolt that you have will probably be fine. Really that bolt isn't even needed because all its used for is to hold the gears on the shaft for assembly of the chain case(makes assembly easier). There is a bearing in the cover of the chain case cover that holds the gears and reverse stuff in place.
Deeppow16
- Oct 19, 2015
Yeah I only know that info because the same thing happened to me last yr haha.yah it was snapped when i disassembled and was told it looks like it was broke for awhile... thanks for the info
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
I left my bolt out. I know other guys are doing the same thing. They say the next one will often snap again anyway. I think I have around six thousand miles on since I've removed the bolt and no troubles
