theewarrior
Any one else notice wear on the inner sides of there sprockets from the clips on the track?
Turboflash
- Mar 18, 2019
- Southern MN
Normal.
theewarrior
No not the normal wear ,, it’s the whole insides not a mark in both my friends sleds
theewarrior
And I also noticed drive speedo sensor wear into the case cover, starting to wonder if the axle is moving side to side a bit,it’s getting pretty deep as well was the wear inner side off chaincase cover
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
The speedo sensor is known to collect a lot of filings which can begin to wear/grind into the inner case cover. There have been many posts on this in the past. I don't know that I would be too alarmed unless its burrowing into the magnesium.
MS
MS
theewarrior
It’s getting pretty deep
klr650r
- Jan 26, 2018
- New Brunswick
- 2018 Yamaha Sidewinder R-TX LE 50th
If there is movement it shouldn’t be enough to throw your track off that much. Is the brake side bearing good?
Maybe the drivers where installed a bit off from the factory?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Who put these clip? They are on the wrong side...:-/And I also noticed drive speedo sensor wear into the case cover, starting to wonder if the axle is moving side to side a bit,it’s getting pretty deep as well was the wear inner side off chaincase cover
And the pto driver to much inside, its like this from factory
Byam has got something there. The track clips are typically installed with the raised vertical side facing the outside of the track window....not the inside like in the O P pics. I will have to check the tracks on my sleds now.
Here is a pic of the right way
Is this normal now...or are the clips installed the wrong way?
theewarrior
This has never been apart, and only started doing this latelyWho put these clip? They are on the wrong side...:-/
theewarrior
Maybe it’s only the bigger tracks that the clips are this wayByam has got something there. The track clips are typically installed with the raised vertical side facing the outside of the track window....not the inside like in the O P pics. I will have to check the tracks on my sleds now.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
My clips are on the outside, not like that! 137 track, could be normal, would it matter? Wear would be on other side and driver.
theewarrior
Think it’s a 153-162 thing
Yes must be...
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
my bad
