livinloud
Hey guy I was out riding today and I noticed an awful grinding noise I tried to putt her home but it got so bad I quit called a cab got the truck and picked it up. Upon further inspection I believe my driveshaft bearing has craped out on me the chaincase oil has gone very milky. So I am wondering how am I going to change it I have done lots of reading and I can't find a good write up on the driveshaft bearing replacement could someone help me out
well you will need to pull the chain case entirely to do the job.
check the spedo bearing and jackshaft bearing while you have it apart. hate for you to have to do them in a couple of weeks when you have it apart now.
livinloud
upon further inspection i know its the driveshaft bearing on the chaincase side then i let the track tension out the shaft has play on the chaincase side only so i am in for a treat right guys.
mbarclay
livinloud said:upon further inspection i know its the driveshaft bearing on the chaincase side then i let the track tension out the shaft has play on the chaincase side only so i am in for a treat right guys.
its not that bad at all to take the chaincase apart. mine did the same thing saturday and I had it apart in probably 30 minutes but Ive had it apart before to change the gears, Im going to be replacing the bearing today if my local dealer has it. It really is a simple job
dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
It wont be so easy if the bearing disinegrated and is froze on shaft. You will need to cut it off. You will see it when you take the speedo housing off. If it was making the noise you described, its gone.
grashoper
- Sep 20, 2010
- Windsor, Nova Scotia
- www.youtube.com
dmaxx said:It wont be so easy if the bearing disinegrated and is froze on shaft. You will need to cut it off. You will see it when you take the speedo housing off. If it was making the noise you described, its gone.
I just completed changing all bearing and seals on the whole machine!! The jackshaft bearing on the clutch side completely fell apart... All that was left was the outer race.. We took a piece of steel... abou3/4 wide, and the same diameter as the race (length)... slid it in the center of the race, and tack welded it onto the race... Took a chunk of wooden dowel about the size of a shovel handle... fed it thru from the chain case side (already torn apart) and lined it up with the piece of steel.. and gave it one wack and it poped rite out.. piece of cake!!.
EDIT: get all your hunk of wood, or even a peice of pipe all ready to rock and roll as soon as the weld has stopped glowing... that way the race is still nice and hot.. and it will come out much easier..
grashoper
- Sep 20, 2010
- www.youtube.com
how did you make out with your bearing replacement??
livinloud
i made out good it was a piece of cake. i have put about 250kms on it since but now i am getting a high pitched wine on it i have no clue where its coming from how do i tell if the chain is to tight?
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Chain is to tight finger tighten only.
livinloud said:i made out good it was a piece of cake. i have put about 250kms on it since but now i am getting a high pitched wine on it i have no clue where its coming from how do i tell if the chain is to tight?
grader
finger tight and BACK IT OFF ONE QUARTER TURN.
livinloud
i did it finger tight and i backed off like half a turn i have no clue what the high pitched wine is. couldit be possible thatits a worn belt?
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Did you check the chaincase oil level?
grashoper
- Sep 20, 2010
- www.youtube.com
geez... u know what... after i replaced all my bearings, I'm also getting a high pitched wine sound.... I've been just ignoring (sorta) it after I re checked the chain tension... I have no idea where its coming from.. I only have about 40% hearing ability, and I don't gear it at all... but my buddy took it for a ride and told me it was there so... I dunno..
livinloud
My chain case oil level is ok next weekend I am going
To diagnose this Issue more throughly
grashoper
- Sep 20, 2010
- www.youtube.com
livinloud said:My chain case oil level is ok next weekend I am going
Cool!! Post back when you find out if you wouldn't mind...
