AAD
- Dec 11, 2018
- SRX
Blew a belt and sled instantly quite at same time.
Installed new belt wouldn’t start without some throttle.
Removed plugs all 3 kinda black but not wet. Replaced all 3 and runs the same rough and poor idle.
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
Have you checked the valve clearence, if you are really unlucky one of the shims is not where it should be.
Turboflash
- Mar 18, 2019
- Southern MN
Yep. Sounds like when belt blew it shucked out a valve retainer. This has been known to happen on this engine. This can often result in valve damage as the next time up, the piston hits that valve and bends the stem. I think your guess is probably right on - it's only running on 2 cylinders. Better do an inspection before running it any more.
Good luck!
Good luck!
Sounds like a valve issue to me as well. Get it to the dealer and hopefully it still has warranty.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yes that's probably what happened. When were racing we data log the runs and when under full power if you blow a belt the rpm spike is crazy. I've seen as high as 11,500
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Spit a shim out for sure. Been there and done that from same blown belt!
Not a fun repair.
Not a fun repair.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Bring back the Zuke
- 14K
