lsp_racing
- Dec 29, 2009
Anyone know if this module increase the rev limiter?
SledFreak
- Feb 7, 2005
- Ontario. Canada
yes...
lsp_racing
- Dec 29, 2009
how many 1000rpm???
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
If I recall correctly you can set the rev limiter to come on to whatever RPM you desire. Does not mean it's healthy for the motor!
lsp_racing
- Dec 29, 2009
Thank you it's for race application!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You must use the Ignition Module in conjunction with the Power Commander. You can increase the rev limiter 500 rpm (to 9900 rpm).
lsp_racing
- Dec 29, 2009
Today i finish my build .... my head is ported, intake custom grind cams, custom piston 13:1, and powercommander .... i will make some test and i will check if i need the ignition!
SledFreak
- Feb 7, 2005
- Ontario. Canada
timing is pretty good on this motor.. If you are looking for all top end, it will help, but for the most part it there is not much of gain any where else in the power band... Any intake or exhaust work done to your build?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Cool - let us know how she runs
