hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I've been stripping these sleds down for some time now and I have yet to find an easy way to drain coolant with out having it all over the floor. To the best of my knowldge there is no "drain". Is this correct?
radianguy
- Jan 1, 2007
On my nytro I put a pan under the sled and pulled the bottom hose off by the oil tank, didn't make any mess.
On my RX1, I remove the clutch side panel. Then slowly take off the hose, into big drain bucket. Seems to be only place that I dont make too much of a mess.
SuperTurbo
- Mar 20, 2004
- Amherst, Ohio
- 17 LTXse Sidewinder
Wet vac sucks it all out. Been doing it for years no mess.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Where do you suck it out from?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
kinger said:Where do you suck it out from?
X2?
09nytro
Bone Daddy
I have a hook from my garage ceiling , saftely secured around beam . I strap up the front and raise it with a ratchet strap. In the rear of the apex I remove the one side of the rear exchanger or tube over a bucket. After I drain it I fill it and raise the rear of the sled and open the rear bleeder.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
same here - i have an old shop vac just for this.SuperTurbo said:Wet vac sucks it all out. Been doing it for years no mess.
mckracker
Take out the rear bleeder, put something like a gear lube nozzle in the hole, put a hose on it to a bucket. Pull the pressure cap off the main reservoir, use your shop vac with the hose on the blow side and put the hose to the reservoir. It'll blow it all out into the bucket. Try and regulate the pressure though so you don't get to much pressure. Works great.
