mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
Left side for me!
judger101
tank off is good to inspect donuts, but if for some reason on your snowmobile trip you need to swap plugs i dont think you will be wanting to take your tank off!
epoxy
- Nov 9, 2012
Everyone says to use NGK CR10EK but why does the manual say NGK CR9E?
Any issue with them?
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
epoxy said:Everyone says to use NGK CR10EK but why does the manual say NGK CR9E?
1-2 more HP...
epoxy
- Nov 9, 2012
Thank you for the info.upei93 said:epoxy said:Everyone says to use NGK CR10EK but why does the manual say NGK CR9E?
1-2 more HP...
Just bought myself a -08 R-TX extended to X-TX and want to see that everything is up to par.
SledWrecker
Anyone running iridium plugs? Which ones if so?
Supa Dexta
Dont know anyone running them, but cr10eix is the iridium cross.
mx1500
i went through left hand side. more convienient, less hasle but takes WAY more patience. after loosening the plug i took a peice of hose to remove the plug and insert new one. quick tip that worked for me, and a tad wd-40 to put that there plastic thingy mabober over the plug
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
- 13 xtx nytro stage 1 turbo
anybody know what size the socket is for the plugs? I am missing my plug wrench in tool bag and can not get a socket to grab?
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
iwillwait4u said:anybody know what size the socket is for the plugs? I am missing my plug wrench in tool bag and can not get a socket to grab?
The same size as your replacement plugs.
Supa Dexta
5/8"
nor'easter
- Feb 12, 2008
- Pennsylvania
- Nytro RTX SE
Lee Rivers
Just did mine yesterday...stubby wrench (14mm) and the spark plug tool...took 10 -15 mins. tops...just reach in under the tank(clutch side).
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
thanks guys I GOT IT!!!
MNBlizzard
I have done it both ways. Removed the seat and slide the tank back, only disconnecting the sending unit wire. I'd say each take about the same amount of time. When changing them with the tank on, use the plug wrench in your tool kit, as it has a special pivot built in to allow it in the tight place. My issue was that I couldn't get the far right coil off, so I removed the battery to get at them from the right too. That made changing them with the tank on much easier.
