Roz
Anyone using a easymove dolly? www.easymovecarts.com It looks good in their video, but is it strong enough to move a 07 Vector full of ice after a ride? Only need to move 8 feet on concrete.
grumpysanta
yes they are well made . i had one for my rx1 and it was great , not good on gravel with small wheels
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
I've been using mine for a few years now. The big wheel kit is needed if you want to use it on gravel.
Rolling the heavy apex around is easy. The best part about this cart is the fact that it breaks down in seconds and hangs flat on the wall. No storage issues!
Here it is under my Apex, but when done, it hangs on those two hooks on the wall next to my creeper! I'm so glad I don't have one of those big hoop style carts taking up the space of an ATV in my garage!!
If you order new, ask for the show price. They always seem to be offering a show discount.
Works on my Viper.
Heck I may even have one that is 15 yrs old new in box.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
The only issue I had with that dolly was when I had both older Trailing Arm sleds and newer long-travel sleds. I usually had to adjust the bunk height between moves. No issue, just an extra step. Now with both sleds built within the last decade, it's easy.
pay2play
Mine works well. The carpet covered wood has developed a bow in it. I bought the extra wheels foe use in snow and gravel. Mostly gets used in the garage. Best part is the easy adjustability and breakdown for storage.
I use this one for my Attak. It converts very quickly from short track to long track. You can leave the sled on it and spin it around on the cart. It also has the optional large wheel kit for snow and gravel.
http://www.jsjacks.com/snowmobile-cart/snowmobile-cart/
boatload
- Apr 11, 2014
- Silver Cliff, Wisconsin
- 2022 Sidewinder LTX SE
Mine is 15 years old and it has worked great on 7 different sleds including the new Vipers. Wouldn't be without one. It's a back saver!
Roz
Thanks for your responses. Looks like I will be giving myself a early Christmas present.
cat hunter
Any dealers in Quebec or Ontario?
IAVECTORGT
- Oct 19, 2011
- Iowa City, Iowa
- 2015 Arctic Cat ZR 8000 El Tigre
I purchased the sledez at the Milwaukee snow show. It came down to the sledez and the easymove. I chose the sledez because of one thing: where the support bar on the lift goes under the bulk head of the sled, there are 4 rubber mounts on the sledez and only the metal bar on the easy move with a non skid thingy on it. The rubber mounts appeared to be easier on the underside of the sled. At the rear of the lift it has adjustable rubber supports for going under the running boards. These keep the sled level while on the lift. So I bought it. Used it twice now and I absolutely love it! Raises my apex easily and I've stored my apex on it for the past couple of weeks. It has wheels and moves around my garage easily. Both were darn near the same price.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
Unless they changed the design from the one on their site, or the one most of us have purchased, the Eazymove has a carpeted bunk under the bulkhead. I bet the one you have will work great though as well. It's nice that their are options in the market for sure.
IAVECTORGT
- Oct 19, 2011
- Iowa City, Iowa
Oh geez! I just re-read the original post. I thought he was talking about the lift/hoist. My bad!Unless they changed the design from the one on their site, or the one most of us have purchased, the Eazymove has a carpeted bunk under the bulkhead. I bet the one you have will work great though as well. It's nice that their are options in the market for sure.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
it's all good, I just needed a reason to post that photo above!!
