PCV only piggy backs ECM. You want to unplug programmer and get the flash done.
tator
then will the pcv need to be remapped as well to keep the afr #s the same?
Alsim
- Oct 6, 2014
- LTX SE 2018
Yes!
My dealer received all to do the re-flash. I'm gonna take my appointment next week for the two recalls .
rebmo
- Mar 8, 2014
- Rural SE Wisconsin
- 2015 Yamaha RTX-DX blk
2015 Arctic Cat XF 9000 Green (Turbo)
I hope you're right on that date, my build date is 4/20/14 (per the build date on the plate behind the seat). I'll have my dealer run the VIN and double check on Monday.There is a cutoff date but I am not sure what it is. I remember only sleds built after April 15 2014, but not positive on that date.
tator
talked to the dealer today and said there is no need to reflash a viper with a programmer installed. so shouldn't need it on any turbo sleds or sleds with the power up package.
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
how is that so^
tator
just guessing the programmer overrides the original ecm. but since i did the turbo upgrade i havent had a start issue. not positive on any of this but just a hunch. maybe need some info from hurricane or mpi ????????
ApexGTman
- Jan 8, 2006
- Newfoundland
- Hers - 2017 Sidewinder XTX LE
His - 2015 SR Viper RT-X LE MPI Turbo with Ulmer Stage II Clutch Kit
2012 Apex SE
2006 Apex GT, Stage 2 Ulmer Clutch Kit, Ulmer Stealth Mod Air Box, 144 1.325" Woody's
2003 - RX1
1998 - SRX
1993 - Exciter SX
1992 - Exciter II
Cold start issues???? We also had that problem with the older apex's but it was a relay for the fuel pump would freeze, should I expect the same from my 2015 Viper?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
The Viper starting issue is crank-no start on a hot soak
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
I don't have my xtx le picked up yet so I think I'll wait another bit......unless it's already done from factory????
I'll have to check that one out.
Fiddlesgreen , your LE wont need a re-flash it been done at the factory, I would pick it up
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
If you needed a flash without a programmer you will still need the flash with the programmer. I assuming you have a GEMS or PCV? Dealer is wrong on that one. If your not having any starting issues you may want to hold off on the reflash? I would have it done for sure.
yamahaguy
Ride SAFE
- Apr 20, 2014
If your doing a MPI turbo there will be a reflash in the future that MPI will be offering that turns the fan on more often to help with cooling.
tator
i have the pcv that came with the hurricane turbo kit. i was having hot start issues before the instal and have not noticed any after. i just dont want to have it reflashed and have it affect the afr numbers. not sure what precautions need to be done. unplug the pcv during reflash? then changing the sleds programing do you need the pcv reprogramed to work with the sleds new mapping to achive the same afr #s?
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
The "hot start reflash" really shouldn't have any effect on your AFR, it should only make a change during the key on sequence with a hot/warm engine. I could be wrong on that but that would make sense. I would call Dave at Hurricane and get his opinion before doing anything.
First of all there is more than one thing the re flash is addressing. Second Yamaha is not saying what exactly is being done. If modded in any way I would be checking AFR's.
