ECU
Wow, that's crazy. Thanks for the update.
It is likely that the ECU has a broken internal connection or some small issue, that's too bad. Glad you got a replacement and its working.
Steiner GOOD job. I thought your were doing CONSTRUCTION up north. LOL
How are you getting the sled HOME?
Steiner, where are you, and yes how do you plan on getting it back this way?
Still working on trying to purchase the sled. IF I do I will get it back home next year when the winter roads opens up again.
Had a chance to take it out for a 90 mile run.
20220429_194128-jpg.168096
@steiner I did a quick read through of your engine thread (The rivet nut theory) and then the ECU, MAN! You had the craziest string of issues! Your resiliency is admirable!
Did you ever take the engine apart and debunk the rivet theory or are we sticking to it?
The ECU issue was not on my sled, but was an easy fix on another guy's sled.
Life would be boring without some crazy things happening once in a while.;)
Had the entire engine pulled apart and the rivet theory still stands strong.
