Electric Shield Hookup
Teamblue4 said:
quebec#1 said:
rindtj said:
What about using an adapter and plugging directly to the 12 V socket on the sled?
Like This !
That is what we use, been using that set up for 3 years now without any blown fuses.
Yamaha sells one with an oring to keep out snow/water. I keep the outlet open for charging the cell for those days it needs it but keep the adapter on board for if/when I blow a fuse or have the grand kid in front.
I use one of these from Kimpex wired directly to the battery. Drilled a small hole for it right beside the accessory plug.
Is it fused?
The yamaha accessory is a ripoff, and it also uses up your accessory outlet, so you cant charge your phone, use gps, etc. I ran my shield cord up through the front of the handle bar riser, and it hangs out a bit (4") from the crash pad, so It turns with the bars, and is up nice and high. No drilling required.
$12.95 is a rip off? I dont get it
Royal distributing page 49 for $9.99 works better than the yamaha one !
http://www.royaldistributing.com/main/i ... eNumber=49
