CaptCaper
- Jan 1, 2007
- Northern N.H.
Teamblue4 said:quebec#1 said:rindtj said:What about using an adapter and plugging directly to the 12 V socket on the sled?
Like This !
That is what we use, been using that set up for 3 years now without any blown fuses.
Yamaha sells one with an oring to keep out snow/water. I keep the outlet open for charging the cell for those days it needs it but keep the adapter on board for if/when I blow a fuse or have the grand kid in front.
quebec#1
The trick is to close the little rubber cap on the entry hole when washing the sled !
KevinS
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
KevinS said:I use one of these from Kimpex wired directly to the battery. Drilled a small hole for it right beside the accessory plug.
Is it fused?
KevinS
Irv said:KevinS said:I use one of these from Kimpex wired directly to the battery. Drilled a small hole for it right beside the accessory plug.
Is it fused?
Its been a while since I installed it. I think I added a fuse.
Wisconsin
The yamaha accessory is a ripoff, and it also uses up your accessory outlet, so you cant charge your phone, use gps, etc. I ran my shield cord up through the front of the handle bar riser, and it hangs out a bit (4") from the crash pad, so It turns with the bars, and is up nice and high. No drilling required.
quebec#1
I bought mine a royal for a few bucks its easy cheap and works well.
Preacher
$12.95 is a rip off? I dont get itWisconsin said:The yamaha accessory is a ripoff, and it also uses up your accessory outlet, so you cant charge your phone, use gps, etc. I ran my shield cord up through the front of the handle bar riser, and it hangs out a bit (4") from the crash pad, so It turns with the bars, and is up nice and high. No drilling required.
quebec#1
Royal distributing page 49 for $9.99 works better than the yamaha one !Preacher said:$12.95 is a rip off? I dont get itWisconsin said:The yamaha accessory is a ripoff, and it also uses up your accessory outlet, so you cant charge your phone, use gps, etc. I ran my shield cord up through the front of the handle bar riser, and it hangs out a bit (4") from the crash pad, so It turns with the bars, and is up nice and high. No drilling required.
http://www.royaldistributing.com/main/i ... eNumber=49
