hypertxer
where does everyone hard wire their electric shield plug. is it safe to wire it to the battery
pedros1983
Mine was wired to the jump start lead coming off the battery on chain case side (no problems at all)... just install an inline fuse to prevent any problems.
Triple X
hypertxer said:where does everyone hard wire their electric shield plug. is it safe to wire it to the battery
Yep, I wired my Apex that way. Just like pedros1983 says, don't forget about the in-line fuse.
blustar
- Mar 11, 2009
- Manitoba
- members.shaw.ca
- Yamaha Apex and RS Vector
Make it real simple.. Wire it to the cigarette power plug which is about 12 - 18" of wire away from the handlebars and this will be wired to only operate when the sled is turned on. If yours doesn't have this then go the battery jump cables on the right side.
Ported Hornet
I wired mine with a inline fuse to the battery jumpers
w8tn4snow
- Mar 28, 2008
- Upstate NY
- 2015 SR Viper LTX DX
How big of a fuse is recomended ?
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Wired mine direct to battery as well w/ fuse. I have a 3 amp on mine.
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
- 2009 Yamaha Apex GT
I wired mine, to teh battery. In 3 different applications (2 Apex's and a Vector) i have experienced a wire burn down once. I believe this was due to the connection being loose. No harm done, and an obvious fix.
I think the advanges of keeping your visor defrost "on" when you are trail side having a pop or two, is worth the effort of going to the battery. You don't have to wait for the shield to catch up when starting out again , on a cold night.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
I was trying to find the yamaha part number for theres and can 't find in the parts help please, the one that comes on the new sleds
quebec#1
blustar
- Mar 11, 2009
- Manitoba
- members.shaw.ca
apltx08
darv said:I was trying to find the yamaha part number for theres and can 't find in the parts help please, the one that comes on the new sleds
Here you go... SMA-DCOUT-PL-UG its expensive but worth it, my bud bought the cheap 1 from Royal as in pic posted by "quebec#1" and keeps unplunging and looses power while the YAM stays in place.
I also HOT WIRED my 12v acc. to battery w/10A fuse so I can back feed my OPTIMATE III, I leave it plugged when sled is not in use, this way you UNPLUG & RIDE! with a FRESH battery every ride, its also very handy for my GPS or CELL PHONE, it stays on even if sled is not running!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
very good.....I love having the 12v acc. wired to battery for constant power....works well for radar gun and with GPS it wont pull all the power from shield and fog me up like it used to....as I had them both coming off same feed.
Dan
Dan
