Philippe
- Feb 8, 2020
- Matane,quebec
- Yamaha nytro xtx 2013
Hello , i have troubles with my nytro xtx 2013. Since the beginning of the season my sled stop working during less then a second when it becomes warm after 15 minuts or more to run and sometimes it shut down everything and write err-1. It broke my ecu, i put a new one on it and still stop working when warm after 15-20 minuts. Do you know what should it be ?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Check your grounds, especially the one from the battery that has a connector mid way. It can corrode or get loose. Cut out the connector and solder the wires together. My son's Phazer had exactly that problem.
If it's similar to Phazers, also check the yellow main ground distribution block (taped up under the wiring harness).
