Kris711
- Mar 15, 2015
- Hudson
- 2017 Yamaha Sidewinder Ltx-se
2017 Skidoo Mxzx 850
I have a sidewinder ltx se. I'm going to upgrade all four shocks. Would you recommend Elka stage 4 or the qs3r 2.0
Sent from my iPad using Tapatalk
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Qs3r's all the way. Elka makes an okay atv shock. Another worthy of mentioning for good value is the zbroz exit shocks.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Or get a knowledgeable shock tuner that's revalved fox shox before to taylor the stockers to suit.
geez150
I would say just revalve your shocks to suit your needs. I had hygear revalve my lxr rear shocks and was well worth the money, will have the fronts done to match the rears.
Kris711
- Mar 15, 2015
- Hudson
I was thinking about revalveing the front shocks but wasn't sure the rears were worth putting the money into
beetongrizzly
- Oct 12, 2014
- Beeton Ont
- 2015 ltx deluxe
I have had both, elkas give more fine tuning if that is what you want , qs3 are easier to understand but would say myself when you understand what the adjustments on the elkas do and how they affect the shock that the elkas are a better shock imo, better resistance to bottoming imo as well
geez150
I suppose it's all in what your end goal is, if you need or want trail side adjustability then obviously you want new shocks.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
I've had some issues with Elkas in the past. They also don't have a very high oil capacity in their main chambers vs the competition. Small diameter. To each their own. Pretty though lol.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I like my Elka
The setup is perfect on my procross
dgjr636
- Nov 16, 2013
- Clarence NY
- Sidewinder LTX LE
If I can say just 1 thing is that the QS3R's work great on the LTX Winder. Not saying that revalving stock shocks or going to Elka's might do the trick but the QS3R's take out the guess work.
I have never had other shocks, Ohlins and KYB's on a sled work as well as these. With just one click it changes everything.
buyrite01
- Sep 15, 2009
- Indiana
- 2017 Sidewinder
Os3 for the money! Easy to adjust on the trail and they flat out work!
Kris711
- Mar 15, 2015
- Hudson
Should I have the QS3's valved or they good right out of the box?
Pstn head
There good right out of the box. I'v been running diffrent conditions through out the day the past two weekends and switched from 1-3 multiple times in one day back and forth and there spot on. Ya with more clicks like the Elkas or Exits etc. I could've tweaked it a little more here and there but it wouldn't be worth the effort to stop and add one click here and there.Should I have the QS3's valved or they good right out of the box?
Also like to point out the 2.0 fronts are not what come on a LE. They are a FOX option. Bigger body. Have only seen them on some Race sleds like the Iron Dog cats. Normally even the regular XC race sleds have 1.5's.
Kris711
- Mar 15, 2015
- Hudson
Do you know the part# for the 1.5
- 34K
