brada
I am curious what anybody has used to put on the tops of the doors on your enclosed trailers to keep the skis from catching when loading? I've seen plastic hinged flip over ramp extension deals that look like they'd work pretty well. What have you used and where did you find them? Thanks for the help.
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
I cut a piece of a bed liner, used some self taping screws, works awesome. sleds glide right up.
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
Saw someone using a length of PVC (probably 2") there and in the gap between the ramp and trailer when open...seeemed like it would work well to protect the edges.
EZ slide guides ground with a bevel.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
http://www.caliberproductsinc.com/
These products work great. Been using them for years. My brother got a new 2 place inclosed and the lip was about 5" thick. They did have a nice design on the lip with an angled pc of Aluminum with a UHMW insert but the carbides still dug in. He bought the Caliber edge guides with the hinges and they didn't work Very well at first. We couldn't locate the Hinge's in a good place to be strong enough to drive on and too let the door close. We ended taking the hinges off the screwing them directly to the lip. Work perfect! they only draw back was the gasket on the door made it hard to close .
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
Yea, I pretty much made the caliber edge glides out of a piece of bed liner..I'll snap a pic when I pick up my trailer at Excell's tomorrow..
pay2play
This is a great idea, sounds about as easy as it could get.Saw someone using a length of PVC (probably 2") there and in the gap between the ramp and trailer when open...seeemed like it would work well to protect the edges.
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
I use PVC pipe about 3 or 4 inch and it works well.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I can get you the caliber hinged guides. Think a set of 2 is only around $28.
wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
The beauty of the hinged guides is they don't obstruct the view of the low lights. A lot of the extensions block a lot of the taillight visibility.
I just made a buffer out of 1" x 3" rip of oak. It had a pc. of L channel screwed to the bottom. you set it over the front edge of the fold out lip and the L channel held it
in place so carbides would not catch on the ramp lip.
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
- 10K
