snow&dirt
- Oct 23, 2007
Had the misfortune of taking a steel fence post directly under oil tank, crushing bottom of tank crimping off the oil line. On first inspection couldn't find any problems on trail. Tried to limp sled to loading point, the result, totaled out sled. I'm upset that the manual has no explanation of engine codes or a red idiot light for low oil pressure (code 30)
I have the following items for sale for a 09 XTX ,Trail Tank 10 gal. Hygear front springs, mountain tunnel cooler and hoses.
09nytro
So......Let me get this right .......You hit a post looked at sled on trail crushing oil tank and hose now its yamahas problem that you didn't look at it closer before you rode it back to load it up
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
snow&dirt said:Had the misfortune of taking a steel fence post directly under oil tank, crushing bottom of tank crimping off the oil line. On first inspection couldn't find any problems on trail. Tried to limp sled to loading point, the result, totaled out sled. I'm upset that the manual has no explanation of engine codes or a red idiot light for low oil pressure (code 30)
I have the following items for sale for a 09 XTX ,Trail Tank 10 gal. Hygear front springs, mountain tunnel cooler and hoses.![]()
How much do you want for the trail tank? if its a reasonable price Ill pick it up... any pics of it also?
Ruckus
snow&dirt said:Had the misfortune of taking a steel fence post directly under oil tank, crushing bottom of tank crimping off the oil line. I'm upset that the manual has no explanation of engine codes or a red idiot light for low oil pressure (code 30)
Ummmm...
Old Thumper
I agree that the owner's manual should have a list of codes. I keep meaning to print one out to carry on the trail.
boritzer1234
I agree that it should be in the manual although I did print off the list of codes. Beats trying to explain to someone back home how to search on the computer over the cellphone!
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
RED IDIOT LIGHT? HMMMMM Maybe a light should of come on in your head that said this isnt good maybe I should have it TOWED home.
