pat the rat
- Mar 13, 2006
Had to remove the starter this week due to the bolts loosening,went for a ride friday,120 km,all good,yesterday we rode 260 km and just before getting home,sled stalled at a stop and gave me a code 30,so i started it back up no problem,oil pressure problem from the code list,seen a few had this happen in the search option,but not sure how it can be fixed,some say to pressure the oil tank???
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Does it still have the code or did it go away after it started back up?
pat the rat
- Mar 13, 2006
The code went away,its been stalling on me lately when i come to a stop,not all the time but once in a while,raised the idle but still the same,maybe its got too many miles,lol
- Nov 1, 2009
- 2009 Phazer RTX
Maybe the plug for the oil pressure sensor is not getting a good connection?
Oil level is good I presume?
pat the rat
- Mar 13, 2006
I did lose some oil when i pulled the starter but checked the level and was about 1/4 lower than full on dipstick,i will fill it up and check the connection on top of the tank,with 27000 km,i've never added an ounce of oil in this motor
- Nov 1, 2009
- 2009 Phazer RTX
The one on the dip stick is an oil level sensor. the pressure switch is beside the oil filter. Try adding oil first.
pat the rat
- Mar 13, 2006
Ok,thanks
It could be the stalling causing the code.Maybe engine rpm goes so low oil pressure drops below threshold.I had code issue today.85.
pat the rat
- Mar 13, 2006
That makes sensecannondale27 said:It could be the stalling causing the code.Maybe engine rpm goes so low oil pressure drops below threshold.I had code issue today.85.
Do you think sticking clutch or to tight belt deflection could be causing stalling?
pat the rat
- Mar 13, 2006
Well,its quite possible,ive been neglecting the little phazer lately,the belt is way past due,i was also thinking the belt could cause that,i'll slap a new one and try it,i'm selling it at season's end,its got alot of miles,like 16000 miles
Wow!
- 53K
