Engine Mounts
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
Are these mounts on the Nytro? No pic but what do you all think of the mounts used on Viper?
No those aren't engine mounts.....the ones below them that are bolted to engine with the black rubber in them .....
Not sure , they aren't used on my nytro ....so they are using the real mounts tho......right..... The ones below those you have circled
Here is good pic of front mounting of Nytro.Still doesnt show what those things are but definitely not mounts.I have not come up with pic of Vipermounts yet.Should have took a pic.
Ok....cool , you had me all worked up....I feel better now
Not sure what they use them for ...maybe something on the vector mounts to them but I don't think so......or could be for molding (casting) or something
I'm heading to sneak peak on Friday. I'll try to get some good pics to post. Anything else you guys want pics of?
Yes!! Some hot women!! :jump:
Where the engine mounts to front and rear would be nice....I'm hopping its not mounted to the heat exchanger
Just those rear engine mounts on heat exchanger. They had a Viper half taken apart at Milwaukee Sneak Peek so you should get a good view.Thanks.
Yes I want to see those too!!
Hey , no need to be sorry , you are just faster on the keys than me.. :jump:
Assembly line support ears. Used for hanging the engine once mostly after all the internals are installed.
Ok..
looking in the snow-tech mag it doesn't look like the engine is mounted to the heat exchanger to me ..looks like its mounted to those braces that yamaha put on that jackshaft goes though.......
