PAvector
- Feb 24, 2007
- Pennsylvania
- 2014 Yamaha SR Viper
Are there any recommendations on starting a reinstalled motor after pulling it. I had the pan ,oil pump out, cam out, fuel lines off.
Can I pull a fuse to prevent spark to pump oil and air out of the fuel lines before firing? Any other thoughts on this?
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 17600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 3700 km
Crank it over with the kill switch off to prevent it from starting and this will get the oil pumping and you can turn the key on and off with the kill switch on to prime the fuel system. Did the same thing after I shimmed my valves.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Remove the vent hose on top of the oil tank and plug the oil tank port with your thumb. Turning the engine over with the vent plugged will cause pressure to build in the tank and force oil to the pump which helps prime the system.
I also added oil to the top at valve cover. Ended up at 4 qts total after running. Seemed to get enough pressure just cranking it over with kill engaged. Never made any noise once I started it. Glad you got it back together. Did you find anything in there?
PAvector
- Feb 24, 2007
- Pennsylvania
Far from back together, just dreaming at this point on what I need to do.I also added oil to the top at valve cover. Ended up at 4 qts total after running. Seemed to get enough pressure just cranking it over with kill engaged. Never made any noise once I started it. Glad you got it back together. Did you find anything in there?
Found this at the bottom of the oil pan.
UGH thats ugly! Take your time you are doing it right and will be able to ride knowing you did all you could. Rotors get scored in Oil pump?Far from back together, just dreaming at this point on what I need to do.
