Joel Beers
- Mar 28, 2019
- Palmerston, Pennsylvania
- 2013 fxnitro rtx
Has anyone on here put eps on an 08 vector using parts from a 10 or 11? What all needs to be changed? Can I just modify my steering gate to accept the power steering?
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
I think you will need a CPU from the "12" Vector ( first year of power steering on that model ) I don't think it would be worth the cost. You should try Snowtrackers Carbides for your skis . They lighten up the steering and you have zero darting
RAMSOMAIR
The ECU will also control fuel injection which the 2008 doesn't have.
Joel Beers
- Mar 28, 2019
- 2013 fxnitro rtx
Yes sorry 2012 is first year for eps I was thinking it was earlier.
I would really like to try this mod just didn’t know what all had to be changed until I get the sled torn apart and the parts needed to do it.
From what I see there is a separate power steering control unit in addition to the ecu so ignition and carbs shouldn’t be effected.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I make a mechanical power steering kit. Much cheaper and less work!
Joel Beers
- Mar 28, 2019
- 2013 fxnitro rtx
Please send me some info. joel@jbhydrographics.comI make a mechanical power steering kit. Much cheaper and less work!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
- 8K
