Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Yes, that's what Im saying.So you are saying you don't have to remove the tank, but it makes it easier if you do? Sorry, not following fully.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
No need to remove tank but it not hard to remove. On my warrior I wound up having to drop the rear of the skid because the flanges would not let go. I used a flat screw driver blade to pry the flanges open a bit but as someone said heat might work as well. Block of wood and a 4 pd hammer was used to free the assembly and yes multiple curse words where used separately and in combinations!
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
I'd rather not pull the tank if I don't have to. Thanks for the tips.
I did look for the instructions mentioned above but saw nothing in the FAQs. I assume the tech area is what was meant?
Is this the article that was being referred to? https://totallyamaha.com/snowmobiles/aaTECH/ApexEngine/ApexEXGasketRepl.htm
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
So you were able to get to clamps from inside tunnel? Clamps were positioned correctly? Did you do anything from above where the seat goes?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
its in FAQI'd rather not pull the tank if I don't have to. Thanks for the tips.
https://ty4stroke.com/threads/exhaust-donuts-y-pipes-step-by-step.52520/
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Thanks for linking to it. All the FAQs I saw were website related. Nothing to do with sled tech. Maybe I was in the wrong FAQ section.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
its a sticky on the top of the forum (apex general talk)
Apex/Attak Frequently Asked Questions
Years and years of technical suport
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Yup I was looking at the wrong FAQs! I need to look through those. Thanks.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
NP anyone who is a first time Apex/Attak owner should spend a few hours reading them.
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Yup, that's what I just did. Some REALLY good info in there, thanks!
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
If I decide to go all the way through the exhaust to check for cracks and the donuts, what replacement donuts are recommended? I've read about copper ones, but seems like some aren't much better than the original ones. Then I read Yamaha came out with new ones that are much better (I think, unless the person was talking about the connection between the tail of the Y pipes where they connect to the muffler pipes).
What would you guys recommend? I think I'm building up the courage to go all the way in and make sure the whole exhaust from the motor on outward is good. Thank you.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Copper will last way better.
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Thanks. Just looked over the text thread from when I was talking to the guy I bought the sled from. He did confirm copper donuts were put in when he swapped the exhaust for the aftermarket one. But I'm not sure he was talking about the ones at the engine. There aren't anywhere the muffler connects to the Y pipes are there?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
no the only place copper ones would be is up front and if they are in there you shouldn't have to tear that apart.
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
Well I think that's comforting. Should I do the exhaust plug test, to see if it will die if I plug them, to be sure? Part of me says just take a look, but I hate to tear all that extra stuff apart if I really don't have to. Anyway to look from underneath? I have an inspection camera.
