JERSEYJOE
TOOK THE APEX GT IN FOR EXHAUST GASKETS. I GUESS I WAITED TOO LONG. HAD TO BUY A LEFT SIDE Y PIPE.WTF IT'S SOOOOO THIN IT CRACKED JUST BEHIND THE FLANGE. IS THIS COMMON?
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
How many miles did you have when it failed?? Also, I wonder if the exhaust gaskets would be covered untder YES warranty....
MNfarmdude
pipes
The gaskets wear thin in about 6000 miles and pipes go soon after.
The Yamaha YES warranty does cover the new gaskets and pipes.
Had it done on mine.
AIRWOLF
Guest
I had to replace mine at 3500 miles and at 7200 miles
Iceman57
You guys that are replacing your pipes (headers) at your expense should check out Excell. They make an aftermarket pipe (header) that is Stainless Steel and adds about 2 to 3 HP at about the same price as the OEM pipe (header).
http://excellmotorsports.com/
Yamaha Man
I agree, check out that new excell header
BADSLED
- May 13, 2004
- Syracuse, NY
2011 Apex SE
I'm hoping to it won't be much longer before they are released...
JERSEYJOE
YES
I DID NOT HAVE THE EXTENDED WARANTEE. I WOULD HAVE PUT AN AFTERMARKET PIPE SET ON AFTER PAYING $385 FOR ONE SIDE OEM.
MINE HAD 5400 MILES BUT STARTED MAKING NOISE LATE LAST YEAR. I SHOULD HAVE LISTENED AND CHANGED THEM AT 4000 MILES. MIGHT HAVE SAVED THE PIPE.
