McLovin
- Jan 30, 2017
- Manitoba
- 1997 Mountain Max 700 144 1.5
Has anybody here had experience with aftermarket stators? My 1997 Mountain Max 700 144 needs a new stator. Yamaha $500, aftermarket $150. It is an old sled, but I do love it!
What would you guys do? Would love to know if you think the sled will be as good with an aftermarket stator.
Thanks in advance for any advice!
TrueBlue
From reading posts on here aftermarket stators don't last long & then you got the labor involved.
McLovin
- Jan 30, 2017
- Manitoba
Appreciate this first response! Will also be curious about whether a used Yamaha part would be better than a new aftermarket.From reading posts on here aftermarket stators don't last long & then you got the labor involved.
Pairodice
Rocky Mountain Atv sells oem parts at a discount. New oem stator from Yamaha $256 Free shipping. I own a motorcycle repair shop. Aftermarket is a last resort, if you have to go that route use rmstator or rickystator
Which part of the stator is bad? If it is just the pickup coil, that can be bought separate aftermarket, and you can leave the rest of the stock stator in place.Has anybody here had experience with aftermarket stators? My 1997 Mountain Max 700 144 needs a new stator. Yamaha $500, aftermarket $150. It is an old sled, but I do love it!
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
I would NOT use an aftermarket stator, unless you want to change it again. I'm pretty sure I got oem from partzilla for around $230 a few years ago.
sideshowBob
OEM parts always...unless they are no longer available
JM.02c
JM.02c
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
If you look up the build specs on a stator it can be rewound with the correct wire they call for. You just have to measure the resistance of the winding and keep winding it until it gets the proper resistance. Then cut and solder the wire on.
i always go oe. heard too many stories about aftermarket ones failing. like to spend time riding more than wrenching.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Yes, even used is better than non oem, there is just no way to know with the aftermarket stuff. Same with car parts I always pay extra for name brand and even then sometimes it's still chinese junk.
McLovin
- Jan 30, 2017
- Manitoba
Thanks a lot buddy! Went with OEM from Rocky Mountain ATV! Gotta take good care of the Mountain Max.Rocky Mountain Atv sells oem parts at a discount. New oem stator from Yamaha $256 Free shipping. I own a motorcycle repair shop. Aftermarket is a last resort, if you have to go that route use rmstator or rickystator
I do agree that stock is the best choice, but we shouldn't forget that Yamaha had horrible stator reliability way back with the 2002 SRX and early Viper 700's. For OEM they were junk!
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Out of the 4 proactions I've owned (3- 2001s and 1- 1999). The Only one that went bad was at about 8000ish miles. A 2001 sx700R
- 7K
