I've currently got the HD drive shaft from Ulmer with the Wahl 2.52 pitch extroverts and was wondering, if anyone knows or if Allen can chime in, if there are ones that have a 2.86 pitch that I can swap them to?
I've got an Arctic Cat XF 8000 (137" track) that uses the 2.86 pitch drive and I would like to have a spare track on hand that would be able to be swapped into either sled if needed.
evil eagle
I would think any extrovert sprocket with a 2.86 pitch that will fit a 1 inch shaft., that the older apex's have.
The 2016 and up apex's have 2.86 extrovert sprockets, but I think the shaft is larger. So they won't fit. I think the design of these extroverts is not very good anyway.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I just got a set of used 2.86 estrovert drivers with a sled I just bought. Guy had used them on an FX nytro.
What size hex is the ulmer shaft?
I finally got the sled out and checked, it's a 1.250" diameter hex shaft.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Will a 137 track (and 2.86 drivers) work with a 136 mono skid and still be able to get the track tight enough?
Sent from my SM-G930V using Tapatalk
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Think the used drivers are for 1 1/16" shaft. WIll confirm
bigbadbow
- Oct 3, 2012
- paradise, MI
- Russia
- Yamahaaaaa
Travis, So if one had a 12 XTX with the 2.52 and wanted to change to the 2.86 would a 2016 drive shaft work or would you recommend new drivers?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
You can put 2.86 drivers on the stock 12 shaft. No advantage to replacing the shaft.
bigbadbow
- Oct 3, 2012
- paradise, MI
- Russia
- Yamahaaaaa
bigbadbow
- Oct 3, 2012
- paradise, MI
- Russia
- Yamahaaaaa
please send me pic of drivers interested!I have some near new that came off my 16 apex (less than 1k miles use). PM me if anyone is interested. $50 for both?
