KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
O -brother. I could care less about being wrong. I would have never thought about a 440 model. You obviously have no sence of humor big foot. Lighten up dude.
Feetsbig
Sorry Knappattack,just didn't appreciate being called goofy.you are right I do need to lighten up.Lets keep this site the greatest source for Yami info and I'm done bickering.
DAGE
- Nov 8, 2005
- where the snows at
- Other
- 06 Attak
I just picked up the 8T drivers on Thursday and they do look a little bigger
here's a couple questions
will I be able to use this on my 1 1/4" ripsaw?
and if I switch back to a 2" paddle will it work?
this is the last time I just take part numbers off the net without checking them out first
Feetsbig
Wont work unless track is 3'' pitch,no matter what lug height,I have a set for sale too
DAGE
- Nov 8, 2005
- Other
- 06 Attak
what a nice way to waste 125$
Feetsbig
exactly what I thought
DAGE
- Nov 8, 2005
- Other
- 06 Attak
sad to see there's some people that are loosing out on some cash over this
can anyone verify that the part number for the 9 tooth drivers is a 2.52 pitch?
Can't someone edit the first post!!! The 8-tooth driver is 3" pitch!!! Doo has never used a 8-tooth 2.52 pitch since they started using extroverts....
Feetsbig
The part # for the 9 tooth 2.52 pitch is correct,I ran them last year,its the 8's that are 3'' pitch
Nate D
- Nov 13, 2006
#504152552 = 3.0 pitch 8 tooth (only used on 06-07 MXZX 440)
#504152503 = 2.52 pitch 9 tooth
#504152502 = 2.52 pitch 10 tooth
To my knowledge, these are the only extrovert/introvert drivers Doo currently offers.
For those of you looking for/at used drivers;
2004 MXZX 440's and Summit X models came with #504152356 (9 tooth) and #504152306 (10 tooth) drivers. These part numbers superseded to the part numbers above in 2005. Apparently there was some excessive/accelerated wear with these original 04 drivers and they changed the design for 05 (though they still look fine on my 04 Summit X) So you may find some of these for sale used, you make the call to use them or the new style.
Ski-doo's that came with the updated drivers in a 2.52" pitch:
05 MXZX 440
05-06 Summit X 600/800/1000
05-06 MXZ X 600/800 w/121" tracks (not renegades)
06 MXZ 550X
07 Summits (all except 550 fan)
07 MXZ Renegade 1000
07 MXZ X 550/600/800 (including renegades and XRS models)
07 MXZ Blizzards
Hope this helps
05 MXZX 440
06 MXZ 550X
07 MXZ Blizzards
Hope this helps
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
i made the mistake ordering the 8t.this post needs to be edited so other people dont blow $.
Feetsbig
Yes,I agree,someone should edit
Did you guys report the error to a moderator? They would be happy to change it if you give them the right info to make everything right.
Tork
Sorry about the incorrect info.
Edited the title of this thread until it is edited and cleaned up.
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
thanks tork.i e-mailed tom last night also.
