Tork
Could somebody check my edits and tell me if I got it right?
And if the info is clear enough?
Extremely sorry about the misleading information that cost some of you guys some $$$
Do you guys mind if I clean up the thread now that the info is correct?
POWERHAULIC
I am truly sorry that I posted the 8t. part number without noting the 3.0 pitch.
I have received a few PM's about driver spacing on the Yamaha shaft. I did not measure when I did it, I pressed the left driver on first and set L. side track spacing to the tunnel, then pressed the R. side on enough to center the drivers in the track windows.
Tork, thanks for helping on this post.
adirondac blue
You can not order these drivers seperatly any more. The only way to order is a assembly(2 drivers on a shaft )for 300 bucks.
Rx-377
MCB has them in stock. Give them a call 810-543-0088
Good luck, Hoawrd Haack
