Vertical
I want to install new extroverts on my 09 nytro xtx with ripsaw 32mm track
What kind should i use?
Brp maybe
Brp maybe
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
brp are good ones but you really dont need on an xtx. The track will not ratchet unless it is very very loose.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
If you go with 9 tooths, you will have to shorten the front of the rails approx 5/16".http://www.ty4stroke.com/viewtopic.php?t=63069&start=15
Mtnviper
- Aug 19, 2003
- Burlington Wa.
Vertical
I dont have a problem with ratcheting now but i have a plan of getting a mcx turbo kit in near future.
skidooboy
go with avids if you are going to boost the sled. check out snowest's yamaha section, that is what most of the boosted riders go for. ski
1yamadog
I put the 10 tooth on mine had to shorten the tip of the rails and shorten the front heat protectors, but the 2.52 pitch seems to be helping my hyfax wear but I also put a small wheel kit on so I'm sure that helps to. Top speed increased but know that would happen. Seems alot better all the way around, but alittle work.
garserio
- Nov 30, 2004
- Fairport, NY
- 2014 SR Viper
2001 AC Z370
2006 AC F120
Wait until next season and buy the new yamaha factory extroverts being offered on the 2010 SE.
sleddingfarmer
you can get wahl extroverts for $150...but my buddy put them on and only after 500 miles on his attak they show alot of wear. He was running his track pretty loose and i guess that is a no no.
I wouldn't buy them, they are cheap but if they wear out i dont think its worth saving the 50 bucks.
- 8K
