hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Updated 9/10/20
RX-1/Apex/Vector parts
set of custom muffin works Billet one piece 136 apex rtx/rs nytro 136 rails…100
11-15 apex D&D Clutch kit. Magna force tunable Weights, Spring, and helix….150
RX warrior or 05 rage tunnel stiffener set…30
10+ heavy duty yamaha drive shaft with extros machined to fit 03-08 apex, vector, rx-1....275
Yamaha RCA handlebar jacks for heated shield from 10+ sleds...45
fox float 1 ski shocks for RX-1 and RX Warrior...200
(3) blue skid plate...50 ea
new muffin works 121-136 tunnel extension bare aluminum...50
new muffin works 121-144 tunnel extensions bare aluminum...50
used 12mm sway bar...50
brand new 11-18 apex seat with red stripe....300
blue and black apex seat for RX-1 or 05-07 Rage & Vector...250
Black and blue oem seat cover for 05-07 RX-1, Rage, Vector...100
black and silver oem seat cover for 05-07 RX-1, Rage, Vector...100
MBRP RX-1 Muffler....150
Updated mono skid front pivot arm for 05-09 mono....200
Power commander V for 11+ Apex...200
Power commander Ignition Module for 11+ apex...200
11+ apex low black windshield...40
2008 Apex 4oth hood....250
big boy spring for Pro action rear shock. 03-04 rx-1, 04-05 warrior and 05 rage....150
yellow Yamaha handguards with mounts...40
Hauk Performance Muffler for 11-18 apex....200
Kimpex back rest..fits apex, vector, rx-1....100
Yamaha Side panel mirror kit for apex & 08+ Vector...50
ohlins mono shock with hygear dual rate springs with adjustable crossover...325
(2) 121" apex/vector/rx-1 rear heat exchanger...100
black/silver 06-10 Apex seat cover...75
(2) good used dupont 121 slide set....$75
Fox Mega Float for any year Mono shock skid.....300
mirror kit for windshield flares on 11+ apex....40
2011-2018 Yamaha Apex Seat pan....125
brand new blue Yamaha full skid plate....80
ohlins mono shock for 06-10 apex....250
06-10 apex seat pan....100
03-08 drive shaft with whal brothers 9 tooth extroverts installed...175
brand new fox mega float...450
brand new ulmer racing remote access hose kit for megafloat shock....125
new CFM heavy duty oil tank for 08-09 Vector...150
121-136 tracks usa rail extensions...100
Schmidt brothers anti bottoming kit.....fits 05 vector, RS Nytro and 07-09 Apex RTX..25
Schmidt brothers inboard wheel kit for 05 vector, RS nytro & 07-09 Apex RTX.....80
Schmidt brothers inboard mid wheel kit for.....50
Schmidt brothers outboard rear wheel kit...50
Schmidt brothers marginal wheel kit for front bend of rail....50
black Yamaha plastic skid plate...50
red Yamaha plastic skid plate...50
(3) Yamaha marginal wheel kit for bend in rail...45
Yamaha soft hand guards...SMA-09HGC-BK-00...50
Hauck Performance Muffler for 06-10 apex...200
Hauck Performance Programmer for 06-10 apex...175
Hauck Performance Ram Air Lid for 06-10 apex...100
Hauck Performance Clutch Kit for 06-10 apex...150
Pioneer Performance 13mm sway bar...60 ea
136 attak/rage auxillary rear heat exchanger 8FT-1241A-00-00....275
Console Knee pads for 06+ apex and 08+ Vector SMA-8FP24-00-00...25
03-08 drive shaft with whal brothers 9 tooth extrovert drivers
like new 128 complete mono 128 skid with powdercoated arms....600
Mono II 4th wheel kit for all 10-16 mono shock skids....35
Apex/Vector Nose Bag...SMA-8FP13-10-00...25
Fox float 3 ski shocks for Apex, Vector or Venture...350
New yamaha windshield bag for hinged hood RX-1, Vector, Venture...30
11-18 Apex mega windshield side flares SMA-8HG96-60-00...40
11-18 apex mega windshield with struts SMA-8HG96-30-BK ( like new) ....100
11-18 Apex Custom running board fuel caddys (1 gal for each running board)..200
Rocz Toyz HID headlight kit...100
Yamaheater plug and play....125
Sled Start Remote start kit with both remotes and instructions...175
(12) Pioneer performance hyfax saving offset wheel mounts ..15 each
brand new yamaha coolant heater SMA-Heatr-CL-NT...40
(2) used BOP soft start springs...20 ea
(5) solid state red relay...10 ea
(4) 7" rear axle spoked red yamaha accessory idler wheels...$15 ea
(6) 5" small spoked red yamaha accessory idler wheels...$12 ea
stainless Excell Headers for 06-10 Apex....300 for set
Yamaha Sport Handle bar bag for apex and 08+ vector SMA-8GL43-00-00...25
New old stock Yamaha Combination top and side saddle bag...100
M20 Airwave 128/129 suspension..like new...1400
SR Viper & Sidewinder
Rocks smart supply plug and play...40
Apex/Vector mx style handle bar pads that say YAMAHA in silver SMA-8GTHP-00-BK....10
Drilled wave brake rotor from LE model....50
blue gytr Yamaha viper rear skid plate...50
sidewinder rear cooler tunnel protectors....30
sidewinder goggle bag...35
Linq 4 gallon gas caddy....165
Yamaha 4th wheel kit for 129 models orange wheels...50
RR 129 skid with orange rails....400 plus stock skid??
yamaha Windshield bag...25
Straight line performance viper muffler...350
straight line performance clutch kit....300
(2) LTX/XTX Yamaha 4th wheel kit black wheels...55
Cat skis with red loops...150
Semi Snowtrackers for cat skis...like new...170
Red Yamaha snow flap...30
MBRP Standard muffler...5" canister...125
Fox Float 3 ski shocks...350
Drive shaft for 129/137 models with only 1200 miles....175
Rocz Toyz HID headlight kit...125
cat plug and play heated shield rca jack...Cat # 0609-965....15
Nytro Parts
Fox float 1 ski shocks…300
new set of blue windshield flares ...30
split rail skis and spindles with blue loops...300
black gytr tunnel stiffeners for slotted running boards (non diamond hole)...150
(2) 2010 + updated subframe...300
Nytro heavy duty Driveshaft with yamaha extroverts...250
RTX 121 rear piggy back shock with compression and rebound adjustment....200
xtx rear piggy back shock...250
xtx tunnel extension...75
oem black and blue seat cover...90
oem black and silver seat cover...90
oem black and red seat cover....90
tall windshield blue with white graphic....75
Hygear Torsion spring spacers for 121 FX Nytro Skid...40
custom Dual FMF rear Muffler setup..100
gytr piggyback ski shocks with compression and rebound adjustment....375
Yamaha gytr xtx tunnel rack with bags....200
(2) yellow Yamaha full skid plates...40 each
(1) red Yamaha full skid plate...40
RTX SE rear skid shock...300
(2) dupont 121 slide set....$75
fox float x piggy back ski shocks from an S....400
mid height silver chrome windshield...40
(2) yamaha windshield bag....35
blue barkbuster trail front end kit.....400
Schmidt brother inboard wheel kit with bell crank & stand offs for xtx. Prevents shock eye wear.....80
Schmidt brothers inboard mid wheel kit.....50
Yamaha black full skid plate SMA-8GL34-00-BK....50
black Yamaha handguards and mounts...45
Yamaha nose bag SMA-8GL23-00-00...20
Yamaha Sport Handle bar bag SMA-8GL43-00-00...25
Phazer Parts
Oem phazer radiator fan…75
Red yamaha gytr skid plate….50
07 Fuel tanks…add 1.1 extra gallons to an 08-16 Phazer.….50
136x14x1.5 freeride track...700 miles on it....400
New Mountaintech oillite a arm bushing kit....80
skinz black skid plate...brand new....115
hygear torsion spring spacers....35
barker exhaust muffler...brand new....300
EHS tuner/programmer....brand new....200
skinz neoprene shock covers for fox floats...brand new...45
Schmidt brothers full (4) wheel axle kit with black wheels...100
Schmidt brothers anti bottoming kit...25
Schmidt brother inboard wheel kit with machined bell crank and stand offs...80
Schmidt brothers machined top ball joints...$40
piggyback rear skid shock for 121 models with Schmidt brothers oil line upgrade (700 miles on shock)...300
Yamaha accessory blue chrome windshield with mounts...70
oem Yamaha tall windshield...60
oem Yamaha windshield mount...60
xtx 144 complete skid with 700 miles...600
xtx/mtx 144 track with 700 miles...475
xtx/mtx 144 rear bumper...125
seat concepts complete seat assembly...approx. 250 miles of use....300
GYTR piggyback resi front ski shock set...350
(4) 7" rear axle spoked red yamaha accessory idler wheels...15 ea
(6) 5" small spoked red yamaha accessory idler wheels...12 ea
Yamaha Tool puch/belt bag...SMA-8GC23-00-00...25
Yamaha 07 phazer belt box....50
Tracks
129 x 15 x 1.25 ripsaw 2 with fast trac studs down center...300
137 x 15 x 1.25 ripsaw 2 with fast trac studs down center only 1200 miles....350
121 x 15 x 1.25 ripsaw 2 fully clipped...like new...350
128 x 15 x 1 hacksaw fully clipped...like new....300
136 x 15 x 1.25 ripsaw 1 fully studded....300
136 x 15 x 1.25 ripsaw 1 with 2 studs every other bar...300
121 x 14x 1 ripsaw with studs....150
121 x 14 x 1 hack saw. no studs...275
(2) ice ripper 121 x 15 tracks...325
121 x 14 x 1" hack saw with no studs...only 700 miles...325
121 x 14 x 1" ripsaw with studs...1200 miles...375
144 x 14x 1.5" phazer xtx/mtx track...700 miles. Perfect shape....475
120 x`15 x 1.5 x 2.86 Talon 38 track with studs for 12-14 Nytro....350
128x15x1.22 ice ripper xt... like new....450
136x14x1.5 freeride track..only 700 miles...400
Misc
mx style handle bar pads that say YAMAHA in silver letters...SMA-8GTHP0-00-BK....10
Misc front shock covers….10 a set
fox shock air pumps...20
rotopax 2 gallon storage box...50
linq 4 gallon fuel caddy...165
Lexin LX-FT4 helmet intercom 2 pack...brand new in box...200
Skis/skags
New 4" pack of 2 carbides for tuner ski...40
tuner ski set for japan sleds...100
blue kimpex arrow dual keel skis...150
Split rail skis and spindles for nytro....300
aggressive snow trackers for 05-10 apex, vector venture skis....170
black C/A ski loops....35
Curve XS skis black with black loops....300
qualipieces cobra head 8" carbides for single keel Yamaha ski...80
black c/a razor skis with red or black loops.....250
qualipieces like new cobra head 6" carbides for single keel Yamaha ski...100
qualipieces cobra head 6" carbides for single keel Yamaha ski...50
set of new woody dooley 6" for single keel Yamaha ski....140
New Studs
(1) Woody's Grand master 1.325 (48) pack.. 75 ea
600 Gold digger 1.075 studs...1.00 ea
Nytro Parts
Phazer Parts
Tracks
Misc
Skis/skags
New Studs
Apextuner
- Jan 31, 2018
- Lac Du Bonnet
- 2011 apex se 2005 rx1
what's the best you can do for Hauck Performance : Muffler, programmer, ram air lid, and Clutch kit. for 06 to 10 Apex?
Race_blue60
Pm sent
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
I have ram air and clutch kit...night and day difference from stock (fix powersports setup).no programming and pulls like hell without.losing top end!!I had no idea how good it was till I rode a stock apex 2 years later..stock apex seems like pulling a trailer comparedwhat's the best you can do for Hauck Performance : Muffler, programmer, ram air lid, and Clutch kit. for 06 to 10 Apex?
blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
do you have any 11-14 apex xtx front skid shocks
My_nanc
- Feb 3, 2017
- Interlake
- 2014 viper
I will buy a tall windshield for a 2008 yamaha fx nytro with the side flares. text 2047689475
MICHAEL DUQUETTE
- Feb 25, 2021
- 03 sx viper er
Is this guy still selling parts ? Thanks
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Yes! Can see his website at Barnofparts.com or call Travis directly at 717-821-9639 or personal message him at @hibshman25 right here on TY.Is this guy still selling parts ? Thanks
MICHAEL DUQUETTE
- Feb 25, 2021
- 03 sx viper er
Thank youYes! Can see his website at Barnofparts.com or call Travis directly at 717-821-9639 or personal message him at @hibshman25 right here on TY.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Travis, do you have an updated version of this list of what parts you have for sale?
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
The website gets updated more frequently than this thread does
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Thanks, I was on his BOP site earlier and missed the tab for these parts but found it this time.The website gets updated more frequently than this thread does
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I will be updating the website list soon. Have some new parts to add.
