uofm
I marred up the faceplate bushing on the primary clutch putting the faceplate back on. Should I take it back off and replace the bushing?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
If its replaceable I'd replace it. You don't want a bad bushing there.
Didn't take the clutch bolt out prior to removal of cover huh?
04mx
- Oct 20, 2015
- canada
- Yamaha
Easy job , did mine in a vice took 10 min .
Fox 2
- Aug 3, 2019
- maitland
- 2020 Yamaha SRX
just did mine , you have to press the old one out and new one in . Part number 90380-28237
uofm
What torque should that be if I take it off and tighten? And that is not a left hand thread is it?If its replaceable I'd replace it. You don't want a bad bushing there.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Torque to 108 ft lbs, back off and retorque to 45 ft lbs is what the manual says. I retorque mine to 60 ft lbs.
