twyztid, which bushing are you using?That is the Teflon that is worn off. Not necessarily from being "dry"
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I still have the stock one in my 15 Viper turbo with no issues. About 3400 miles now. I'll be replacing it with a ToughMet3 bushing before next season. It is a bronze alloy bushing with 15% nickel content.
Ok, I though I recently seen one in a pic u posted a while back. Is there a part number for that one?I still have the stock one in my 15 Viper turbo with no issues. About 3400 miles now. I'll be replacing it with a ToughMet3 bushing before next season. It is a bronze alloy bushing with 15% nickel content.
Fast
- Sep 25, 2018
Did they mention a time frame like this year or somethingJarett from Yamaha says it’s happening.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
74Nitro...
I have 10-11 SAE660 bronze bushings but I have not installed any of those. Others have uses that type.
The ToughMet3 bushing is a TMCB161808. It will need to be sanded/honed out to fit on the shaft once it is pressed into the bushing.
I had contacted the manufacturer to see if I could get some made that would be the right I.D. after pressing into the gear (and the right length) but they are asking me what the exact specs need to be and I do not know that yet. We may be talking only .003"-.006" larger ID that what they normally manufacture.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
That would be a “NO”
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I finally took my upper gear off after 3000 miles with the bronze bushing from
Bronzebushings.com and am happy to report almost no wear at all!!!! I would not hesitate to put it right back in. That being said, I did order the DMC bushing and will be running that next. I will keep the gear as a spare.
Exactly what I'm doing Stain. Got the DMC gear in the sled for this whole year. I put on 5k-7k per year, so it will be a good test.
Mototown
- Sep 11, 2018
- Apex 40 th
I made a bronze bushing this time last year , zero wear running it again this year .
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Which one did you buy? The CB1618-08 SAE660 Cast Bronze bushing? Did you have to hone out the ID for it to fit on the jackshaft after being pressed into the gear?
Yes, you will have to hone the bushing a little bit to get it to fit on the shaft. I used a 1" dingle ball hone on a drill.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
ordered from bronzebushings.com
AA-1110-1 | Oil Impregnated Bronze Sleeve | 1 ID x 1-1/8 OD x 1 OAL
101493 $3.39
Ordered: 1
Shipped: 1
$3.39
I did NOT have to hone it out to fit.
101493 $3.39
Ordered: 1
Shipped: 1
$3.39
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
2011 APEX 32000KM , NO CHAIN CASE ISSUES
2017 SIDEWINDER , UNTIL , 8900 KM NO ISSUES
2018 SIDEWINDWER UNTIL , 6500 KM NO ISSUES
2019 SIDEWINDER UNTIL , 5500 KN NO ISSUES
2020 SIDEWINDER UNTIL , 3400 KM NO ISSUES , WTF , BROKE 2 ND RIDE
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Which side of the gear are you guys leaving the extra width hang out? The flat side or the side with the reverse gear teeth on it?
It would be the flat side.Which side of the gear are you guys leaving the extra width hang out? The flat side or the side with the reverse gear teeth on it?
- 30K
