Fault code
michigun
Age
49
Phazer gt rtx
Do phazer codes self cancel after repair is made??? Or do you have go into diag mode and clear them. Or is diag mode for code history. Did a oil and filter change and now have a code 26, surprised cause I can see the map hoses are on there. Will pull airbox and check both ends of hose etc
From front of machine is cyl #2 on the right?
Check the condition of the hose. Could be cracked or detached from the other end. Codes cancel themselves on each restart unless fault still exists.
