Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Lots of garage testing. DMM voltage measured across the battery posts while running. My issue comes and goes, and i can often get it to happen just idling in the garage.
What about stored codes?Lots of garage testing. DMM voltage measured across the battery posts while running. My issue comes and goes, and i can often get it to happen just idling in the garage.
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Thought I was replicating the problem at one point by moving the harness around under the guage pod, where the headlight plugs and handlebar accessory plugs are, but did a lot of digging there and didnt come up with anything. Removed all the wire coverings, disassembled the headlight plugs, disconnected all the other plugs.....same results.
Where you thinking any in particular that might lead to something else to check?
May have been another code at one point, but unfortunately all my investigation was last season and I dont remember what it was. I do remember being fairly confident I ruled out what ever it was. Havent replicated my issue yet this year and currently have the sled torn down hoping to find the missed rub through! Haha. I will let you know if I can get it to throw a different code when I get it back together enough to runWhat about stored codes?
Check to see if there are any stored codes.Thought I was replicating the problem at one point by moving the harness around under the guage pod, where the headlight plugs and handlebar
Have you done the AC volt test from the stator with machine running?
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Yes, I remember it was good, but dont remember what that was. 51v ac ?? its been awhile.. And like I posted, The sled idled fine for several minutes with the Stator disconnected, and then threw the code and started to run rough, same scenario as when the stator was connected. Battery was new and was fully charged at the time.Have you done the AC volt test from the stator with machine running?
I will check for stored codes when I get it back together enough to do so....gotta lot of wire bundles to rewrap! lol Thanks for the help
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
OK, stored fault codes were 22(Air Intake temp) 46 (Power supply issue) 81 (Grip warmer) and 84 (TORS) I erased the codes and will have to wait till I can get oil to start and run it.....she is still torn wayyyyy down and wont be riding anytime soon. But hopefully it will act up in the garage so I can see if it throws any of the same codes.
Can I test the air temp sensor? But im not sure it explains the voltage drop at the Battery, which is consistant with when it starts running rough.
84 TORS...same, I could see it intermittently causing it to go into limp mode, but no voltage drop unless there is a short somewhere?
code 46, yepp there definitely is a power supply issue....just gotta find it! lol
And Grip warmers have tried unplugging them, with no change....sled will run fine, then it wont.
Whats your thoughts? Any common issues with the TORS? perhaps a short in the throttle position sensor that would cause all my issues?
Also, I dont see the thumb/grip warmer switch on the wiring schematic? Would like to know if there is a way to test that also.
Thanks again
Thanks again
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Does EVO open up the ECU when they do the hand warmer flash? If so that would be a good place to start looking for issues in case it wasn't sealed properly.
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
I dont think so, i believe it is just a reflash of the program that controls the handwarmersDoes EVO open up the ECU when they do the hand warmer flash? If so that would be a good place to start looking for issues in case it wasn't sealed properly.
46 is power supply to the FI system is not normal. I have seen this before, usually the cause is the female connectors in the plug that plugs into the starter relay.
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Yeah, ive had it throw 46 when I had a loose battery terminal also. Ive replaced the Starter relay, and cleaned and dielectric greased the connection between the two, but will see if I can pull each connector from the plug and see if I can clean them even better.
The best way to check these is take a male prong off an old harness(or remove one from the block of a good harness if you have no old parts) and insert it into each of the female terminals. It should grip with a bit of firmness. Its hard to tell by looking at them.Yeah, ive had it throw 46 when I had a loose battery terminal also. Ive replaced the Starter relay, and cleaned and dielectric greased the connection between the two, but will see if I can pull each connector from the plug and see if I can clean them even better.
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Thanks, will give that a try.Similar threads
- 9K
- 8K
