GoHomeYammi
- Mar 14, 2011
- Central Ontario
- 2015 Yamaha viper RTX LE
Picked up my 15 rtx le yesterday i had a hurricane 240 kit installed. It seems to really pull hard but conditions and trails that end quickly have stopped me from getting a good wot pull. One question for guys that know turbos..I assume its the wastegate thats making a huge popping noise under hard acceleration like a whaaa pop pop. Its not the rev limiter and air fuel seems to be where it should so im hoping its not lean backfire.
Pretty awesome machine it blows the doors off my nytro with this setup. I do feel like it steers way heavier though.
- Nov 29, 2009
- sabattus, maine
Description sounds more like rev limiter to me
GoHomeYammi
- Mar 14, 2011
- Central Ontario
I thought i heard it in the 7000rpm range multiple times but there is a chance i looked at the tac to late or something. If thats the case i am constantly banging the rev limiter with this clutching.Description sounds more like rev limiter to me
CustomApexMan
Wastegate makes no noise the blow off valve could make noise but that's only when you first let off the throttle
GoHomeYammi
- Mar 14, 2011
- Central Ontario
Primary: inner 2 tungston 1 washer
Middle empty
Tip 2 washers
Secondary purple spring 1-0
Hurricane helix
Gearing 24 top 41 bottom
Sometimes the pop is very loud it really doesnt feel like the nytro rev limter
Middle empty
Tip 2 washers
Hurricane helix
CustomApexMan
Wow that's really light on the tip will it even go over a 100
CustomApexMan
Boy that's tall gears for a rtx that's the gears I'm running on a xtx
GoHomeYammi
- Mar 14, 2011
- Central Ontario
Im riding in city limits on tight trails i havent gone over 80mph. So no wot expierence.Wow that's really light on the tip will it even go over a 100
DC5
That is definitely your rev limiter, the tach is slow to catch up so you can hit the limiter without seeing it on your tach, you need to use the max rpm recall to see it. What belt are you using?
CustomApexMan
You need to take some weight off the bottom and put it on the tip I'm at 6 washers bottom 0 mid 7 washers at the tip and that's 270hp
GoHomeYammi
- Mar 14, 2011
- Central Ontario
8jp belt. I bought a 8dn to try as well. I will check the max rpm recall thanks i did not know it had one.
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
Definitely over rev. Mine has done it as well
HURRICANE
Check your boost pressure.You should be at 10lbs.It sounds like it may be overboosting.If thats ok then let me know where it hits the rev limiter.From dead stop or does it climb to it?You don't want to remove weight off the heel for sure because the turbo spools instantly.You need the weight there
GoHomeYammi
- Mar 14, 2011
- Central Ontario
I just took it back out for another test. I saw 13 pounds of boost at 7200rpm and would hit the rev limit imediatly after. Max rpm is 9350. Sounds like it is over boosting. Where do i start with adjustments?Check your boost pressure.You should be at 10lbs.It sounds like it may be overboosting.If thats ok then let me know where it hits the rev limiter.From dead stop or does it climb to it?You don't want to remove weight off the heel for sure because the turbo spools instantly.You need the weight there
HURRICANE
There is a boost bleeder in the blue actuator hose. Its likely installed backwards
- 8K
