leaddog
My only problem with it was when standing up. Letting off of the throttle would throw me over the wind ornament. Got er fixed now.
SledFreak
- Feb 7, 2005
- Ontario. Canada
I bet you can answer that one....Viper34 said:Next Tech comming soon.... How to blow your buddys apex away for less then $100 bucks.
Rotax! said:I bet you can answer that one....Viper34 said:Next Tech comming soon.... How to blow your buddys apex away for less then $100 bucks.
Thats easy...
"Hey buddy, I'll give ya 80 bucks if ya let me win a race"
LOL
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
Yes, this is normal. Watch your tachometer to see the rpm where you feel the release then compare that to the rpm where you feel the clutches engage. I'm betting the rpm's are pretty close.RED800 said:is it just mine,when i let off the gas,the engine brakes a little then it releases and rolls until i hit the brake..do u guys know what im talking about
- Mar 1, 2004
I also like the E B'ing......no need 2 ever really use the brake, let the back end come around by using the E B unless maybe your studded.
welterracer
I am soo usto the engine braking after owning 3 fourstroke sleds that alot of the time i catch my self holding the throttle and hitting the brake at a stop sign at the same time..
Sometimes i wish i didnt have the engine braking but most of the time im glad that i do..
- Mar 1, 2004
BTW...........UR friends will soon learn 2 hate driving behind U....
.... BECAUSE U NEVER USE THE BRAKE.............NO BRAKE LIGHT
Tinker
After my buds first rides on their Attak and Apex, this will come as a relief to them and me. I was expecting that maybe a ECM programming change could be done to keep the engine from returning to idle immediately. Is there no detriment to a high idle. Is there no TPS calibration that needs to be done with the FI. A higher idle was the first thing that I felt would help 'cause your never gonna push that motor by the center shaft of the primary when it's open. The Attak rider is comin off a Poo XC8 and the Apex rider is comin off an 03 Rev8 and the precise throttle control is tough to get used to.
Feels kindu good to be back here.
Cheers
Cheers
novarossi
- Dec 26, 2005
Yea, thats no joke. I almost got nailed from behind several times already, I now try to tap the break to flash the lights. But its better than being in the back, sucking 2 smoke!BOUNTYHUNTER said:BTW...........UR friends will soon learn 2 hate driving behind U....
.... BECAUSE U NEVER USE THE BRAKE.............NO BRAKE LIGHT![]()
MADDOG24
I agree. You can can induce some oversteer and get the sled to rotate thru turns better.
wavey
I like how much cleaner the sled stays. Less braking/less brake dust.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The effect of the engine braking will fade after 2500 mi. or so. You can't belive the diff. between a broken in machine and a new one! You will be using your brakes at 2500 mi.! Mike Knapp #17
APEXER1
- Jan 3, 2006
- Catskills, New York
- purdyracing.com
I can see most of the people on here are die hard Yammy guys. I was trying to help out the new guys that are comming from a ski doo or polaris that find the braking annoying. On tite trails where i'm from my doo 800 corner to corner would leave an rx1 in the dust HANDS DOWN !!! By setting my idel at about 1600 even 1700 it really helps BIG TIME. Don't worry yammy guys it doesn't kill the braking that much at higher speeds. You guys do alot of talking but you probaly haven't tryed it yet. First try it then give an honest reply. IF YOU CAN BE HONEST........
Happy trails...
Happy trails...
APEXER1
- Jan 3, 2006
- purdyracing.com
OH ! I forgot something. That $100 bucks was slaped right in my hand after i beat my friends apex gt by 2 1/2 sled lengths. Just the week before we were dead even. He wanted the little trick i did. LOL!!!!!!!!!!!!!!!!!!!!!!!
MOTOWN SPEEDFREEK
Ilove my engine brake, got used to it in about 4or 5 corners.wouldnt ride without!!!
