murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
What's the difference and advantage of a flash with or without a 3 bar map sensor, which is the better route?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Flashes under approx 17psi 3bar sensor not needed, with exception of Stock muffler tunes.
Dan
Dan
I like running the 3Bar maps because you know what's going on. You can see how much boost you're making. If you're running the 270 tune or higher I recommend it.
Kenneth Rogers
- Jan 23, 2019
- Fort McMurray, Alberta
- 2021 Sidewinder SRX LE
2018 sidewinder xtx-se 137”
1997 Vmax 4 800 shorty
1996 Vmax 4 800 shorty
1995 Vmax 4 Improver
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
The better the info for the ECU the more reliable the motor will be I would say. If you’re making boost beyond what the stock map can read you’re giving the ECU unreliable data to make decisions.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Reason for asking is that I have a buddy that want's to swap ecu's, he's got hurricane 270 flash that doesnt require the 3 bar map sensor, should I go for it or stay away?
The 270R tunes run flawless and don't require a 3Bar sensor to run. If you do want to more closely monitor your boost you can add the 3Bar sensor which will require the 3Bar map update
Winderallday!
Its my understanding Hurricane now tailors their tune bundles (Stock Muffler and Performance) for a 3 bar sensor, maybe in the earlier tune generations they didn't, but recently they have been recommending 3 bar, especially for stock muffler tunes.Reason for asking is that I have a buddy that want's to swap ecu's, he's got hurricane 270 flash that doesnt require the 3 bar map sensor, should I go for it or stay away?
If you have a recent tune bundle set up to look for a 3 bar sensor, it will throw and error message and sled will not run right if you try and run a 2 bar (stock) sensor. So basically the tune is set up for one sensor or the other, would need to contact Hurricane to understand why they prefer 3-bar across the board now.
HURRICANE
The Hurricane stock muffler 270 flash will have more predictable boost control and will make more Hp with a three bar map sensor.this year many guys decided to add a three bar sensor to the 240-270&290 performance muffler flashes. This often created an overboost condition and subsequent boost cut. As a result we created all new flashes for the three bar map sensor to be used with performance mufflers. The new three bar performances muffler flashes are 240-270&300hp.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Dave is it good, doesn’t give you any more, correct? Like I have your 270 performance with 2bar map, going to 3 bar with reflash for it, will it be different,still 270 hp right.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
There is no difference in the 270 tune whether its the 2 bar or 3 bar, its still 270-275 and runs the same. With the three bar however you get the 300 tune in place of the 290.
Nothing wrong with the stock 2 bar either way.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Here is one of the better discussions I have found on this topic:
https://www.turbododge.com/forums/f4/f15/74620-2-bar-3-bar-map-sensors.html
lilrez
Didn't Dave replay on post #8 "The Hurricane stock muffler 270 flash will have more predictable boost control and will make more Hp with a three bar map sensor."
KnappAttack
- Feb 19, 2004
- Welch MN
Read it closer. Thats for the STOCK MUFFLER flashes, not the performance or tune for higher flow mufflers.
lilrez
ah ok... gotcha
Carpet Guy
I just had the stock muffler tune done 225,240,270 should I have it and can I go up to 290 with stock muffler? I also added the dalton weights but would like to come out of the hole quicker what's your thoughtThe Hurricane stock muffler 270 flash will have more predictable boost control and will make more Hp with a three bar map sensor.this year many guys decided to add a three bar sensor to the 240-270&290 performance muffler flashes. This often created an overboost condition and subsequent boost cut. As a result we created all new flashes for the three bar map sensor to be used with performance mufflers. The new three bar performances muffler flashes are 240-270&300hp.
- 7K
