06attack1
- Jan 12, 2006
Going out west with my Attack, do I need to do any changes?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Yes, ski's!06attack1 said:Going out west with my Attack, do I need to do any changes?
If going to the mountains should have a air bag vest like KbxSrx is selling would be the best along with a beacon and shovel. Or a beacon shovel and probe.
SRXracer
Seriously IMO, if you are gonna do any sort of off trail riding, i would rent mountain sleds out there. I have been out there a few times, and we've always rented some longtrack stuff out there. The one day some guys on 121's tried to follow us and the literally made it about 50' off the trail before they were all buried. The attack would be a little better, but nothing like a 151 with a 2" paddle.
snowATTAKer
I drilled out my weights on the clutch. Yamaha also says to change the top gear and chain on the gear case. I opted not to do that. I am heading to Wyoming Friday night. I also have the mountain skis installed. I lived in Colorado and snowmobiled for 5 years with a short track.
I find as long as the rider knows how to control the throttle and go off the trail with speed and then the trick is too maintain your speed. You can even break trail with a short track as long as you dont get too fancy on your turns. Always stop if you have too on the top of a burm or hill so when you take off again you are going downhill to get your speed up again.
JERSEYJOE
Going out west with a 121? You got bigger balls than I do!
Well you wont be doing any boon docking but you can get up there and play a little on the harder packed stuff.
The attack is a 136"
snowATTAKer
A 121" does have it's limits. If you just have to ride ( and we all do ) the trails and a lot of meadows would be awsome.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You may want to pick up a O-S-O primary spring for out west. This will leave engagement stock but raise the rpm throughout the shift curve.
you would be suprised what a 136"x2" trtack goes through.
pro116 said:you would be suprised what a 136"x2" trtack goes through.
Rider skill is the most important component!
Srxspec said:You may want to pick up a O-S-O primary spring for out west. This will leave engagement stock but raise the rpm throughout the shift curve.
LoneViper
It wasn't to long ago that a 136" track was the longest and we thought it was the greatest. just go and have fun, park headed down hill, stay on the upper side of the road, and always leave yourself a way out.
