deerlodge
I have a 05 rx1 with a simmons turbo kit, ever since I have owned it it would run rich when taking small jumps. If I was to do a big wheelie and come down without being on the gas it would flood out, and I would have a hard time starting it. has anyone else had this problem before? any ideas what to look for?
Rich
Rich
Ted Jannetty
deerlodge said:I have a 05 rx1 with a simmons turbo kit, ever since I have owned it it would run rich when taking small jumps. If I was to do a big wheelie and come down without being on the gas it would flood out, and I would have a hard time starting it. has anyone else had this problem before? any ideas what to look for?
Rich
float levels too high, No blow off valve,
deerlodge
I dont have a blow off valve,
someone suggested billet carb tops, would that have anything to do with it.
I have a blowoff valve and it is still happening. I would love to hear some suggestions.
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
You also should have the mountain float bowls installed on these to help stop this problem.
Ted Jannetty
Must haves with a turbo or supercharger
Billet carb caps.
Billet carb Tees
Mountain float bowls.
Blow off valve
Wide band Air fuel gauge
Ted.
Billet carb caps.
Billet carb Tees
Blow off valve
Ted.
77srxdude said:I have a blowoff valve and it is still happening. I would love to hear some suggestions.
I had the same problem with bosh bypass valve , correct fuel pressure, correct float bowl settings and mountain float bowls on the Bender kit. I did as Hurricane and Dave @ Powdelites suggested - moved the pressure signal for the fuel regulator from the plenum to the carb boots (all T'ed together). Problem fixed
That beeing said - I upgradeed to a Vortech Bypass valve from Ted J. after doing this (installed before the float bowl pressure signal pick up) . This was done to make sure I had a valve that was big enough. This takes care of the lean problem that can be caused by this setup when crusing with no boost for a long time (engine is seeing vacum and a plenum is seeing a small amount of boost/pressure)
Thanks guys - I do not have the mountain float bowls. I do have the lines t'd off the carb boots.
I will get the other bowls and see how that works.
Thanks!
Thanks!
Ted Jannetty
77srxdude said:Thanks guys - I do not have the mountain float bowls. I do have the lines t'd off the carb boots.
Thanks!
I have 2 sets of complete carbs with the mountain float bowls if any one is interested.
Ted.
deerlodge
im going to try the T's and billet tops, if that doesnt work im going to steal my Mom's MTN float bowls off hers , she would never know the differance
Ted Jannetty
deerlodge said:im going to try the T's and billet tops, if that doesnt work im going to steal my Mom's MTN float bowls off hers , she would never know the differance
LOL, Just until she tries to climb a steep hill.
deerlodge
I dont have to worry about that, she just cruises on the lake.
do you have the carb T's and tops in stock ^
Ted Jannetty
deerlodge said:I dont have to worry about that, she just cruises on the lake.
Yes Caps and T's in stock call 203-753-7223
turbogriesbach
- Sep 14, 2008
- Hortonville,WI. U.S.A.
- 2006 Apex RTX
2010 Apex RTX
2005 RX-1 TURBO
- YAHOO
- kevingriesbach@yahoo.com
What's the part no. for the mountain float bowls or who sells them? thanks.
Ted Jannetty
Re: mountain float bowls
The part number is not recognized by the yamaha parts system I tried many times but NO Good.
I have 2 used sets.
turbogriesbach said:What's the part no. for the mountain float bowls or who sells them? thanks.
I have 2 used sets.
