You were correct. Easy install. Ran for the first time Saturday. 55 psi put my A-frames just slightly above level. Real nice improvement.Macheater said:You shouldn't need to. Only the oem Yamaha floats use the bushings. The aftermarket use the solid rodend type of mounts. Much better than the urethane bushings.
