hygear
TY Advertiser
- Nov 29, 2008
- lansing, ny
- www.hygearsuspension.com
The Single Shot Solution!
Hygear Suspension has developed a coil over solution for the Yamaha Apex and Vector chassis using the single shot rear suspension. The undersized stock 1.5 float shock is replaced with a much larger 2.0 Fox Coil platform that is built using Hygear Suspension’s custom Fox H1 build specifications. The shock features include large capacity damping control that is more suitable for single rear shock suspension applications. It offers spring preload and low-speed compression adjustment that provides reliable service for trail conditions. The shock kit comes with additional accessories needed for mounting that also helps improve suspension movement. Testing has proven there is a major difference in ride performance that feels much more comparable to the original Yamaha Mono shock applications. The suspension now utilizes full travel to help smooth out the small to medium size high-speed repetitive stutter bumps with improved bottoming resistance for larger moguls. - $949.99
Gets yours today and order from the link below:
https://www.hygearsuspension.com/products/fox-hygear-h1-apex-single-shot-2-0-ra-coil-over-rear-kit
Do you have additional questions, feel free to call us!
607-533-7434
607-533-7434
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Looks like you are installing different coupler blocks with this shock.
What is the benefit of the different blocks and are they shorter or longer?
607-533-7434
Might have to get one of these to give it a try.
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
$1000.00 for a shock, getting to be a little stupid on prices. But i guess if yamaha can't make one that works ya gotta pay.
