thetruck454
I pulled the heat shield off under the gas tank to try to get at the last rivets for the tunnel protectors. Failed attempt, but what I did notice was that thermal cloth is all falling apart and right above where each exhaust tube is, it was gone. So that heat shield would be more like a heat conductor with the bare aluminum showing in some spots. Any one else notice that?
Also since I had to drill the rivets out, I need to replace 16 of them. I had some 3/16" (4.7mm) and they looked to be a bit too small. I'm assuming they are metric and the next biggest size is 5mm?
