snowy1
I think there is a big difference between trail riding in the east and west, most have found that you need to run some race fuel in the west if you want the motor to last. I think thats most likely due to the way we ride, deep powger all day climbing hills with the throttle wide open heat soaking the motor. you can not ride a groomed trail all day with the throttle wide open with boost, not and live through it. so weather we are running 8 lbs of boost or 20 lbs. alittle race fuel is needed. I have seen many motors go down out here on 8lbs. at 10,000 ft. trying to run pump fuel all the time. so to us a trail sled runs race fuel and most of them have nitrous as will, especially if you go to a shoot out. if you don,t have nitrous you may as will stay home, that may be why the rear mounts perform as will as the front mounts out west when set up properly. we don,t have one groomed trail in the entire state.
