NytroAl
- Dec 21, 2017
- Massachusetts
- 2009 nytro
Hey all,
My 09 Nytro is leaking gas when it sits for a while. I topped the sled off , rode 25 miles with only 1 bar on the gas guage missing. The sled sat for about 5 hours and when moved i noticed a large gas puddle in the snow, with only 2-3 bars remaining on the gas gauge. Any certain areas along the fuel lines/ fuel pump to check later on when i take the machine apart? I have a trail tank installed on it as well, and the sled gave me no trouble last season. Thanks guys,
Al
Al
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Where does it smell like its coming from? The engine compartment or under the seat?
NytroAl
- Dec 21, 2017
- Massachusetts
- 2009 nytro
Not exactly sure. It looked as if the leak was directly under the skid plate in front of the track. Is a certain smell given off whether it leaks from under the seat or engine compartment?
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
Pull the tank. Sometimes the trail tank suffers from rub through issues.
https://ty4stroke.com/threads/trail-tank-warning.149969/
NytroAl
- Dec 21, 2017
- Massachusetts
- 2009 nytro
Will do. If the tank in fact has rubbed through, is there a quick temporary fix for it until i could get a new tank?
Keith1962
- Mar 26, 2015
- Camillus, NY
Probably. I assume its made of high density polyethlyne. Here's one method.
https://www.instructables.com/id/Repair-Plastic-Fuel-Tank/
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Check your vent line
It is located up high and could come loose letting gas slosh around
But based on you description it sounds like something else
Ms
Ms
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Check the fuel pump flange on tank mine leaked there. If its leaking there pull pump and use some permatex or silicone gasket maker that is fuel resistant and let it sit overnight before using.
Pete
Pete
NytroAl
- Dec 21, 2017
- Massachusetts
- 2009 nytro
Thanks for the replies guys. I rode A little bit this weekened with neary a drop of leaked fuel showing while the sled was sitting. Seems to me the leak has slowed down somehow, but I will tear it down when I have some free time on Tuesday and report what I find. Thanks again,
Al
Al
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Wife had a fuel leak with trail tank on her '09 XTX, it turned out to be the rubber gasket for fuel pump dried up and got brittle.
Really don't want to mess around riding it much with fuel leaking, especially with a hot exhaust pipe under it.
NytroAl
- Dec 21, 2017
- Massachusetts
- 2009 nytro
It Looks as if the trail tank itself is leaking at a seam. I will take and post pictures to get your opinions. If so, looks like a new tank is in order
NytroAl
- Dec 21, 2017
- Massachusetts
- 2009 nytro
The leak appears to be at the bottom of the tank behind the secondary clutch. The 4th picture is one of the interior of the tank. Circled is what i think appears to be some sort of warp where i think the leak is. The sled is going to the shop so i can get a concrete answer and solution to the problem.
