99SRX700
I have decided to install a fuel shut off valve on my 05 RX-1 after hearing all the stories about trailering with a full tank. My question is where do I get them and where do I install them? Can I get them through the dealer, and where in the fuel lines do I install them?
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
There is a couple threads with great pics. Do a search and they should come up.
The dealer sells shutoffs as does most auto stores. I got mine from Napa.
JDKRXW
While you are cutting rubber lines, you might as well install a coolant shut-off valve to the carb heaters too. I used a Ski-Doo valve on this line (expensive thought).
I thougt the carb heaters were automatic?(shut off after certain temp) is this wrong? Jay
grader
xc8j, the electric carb heaters shut off after a set temp. the shutoffs are for the coolant.
So the electric heaters don't shut off the coolant? Talk to me about coolant shut offs! Jay
JDKRXW
I'll talk all you want..... after you do a search on the topic.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
The carbs are heated 2 ways; Electrically for instant heat and by engine coolant. Once the engine gets to temp the electric heaters are turned off while the coolant is still pumped. Many have installed a shutoff on the coolant line on the left side as it leaves the carbs. This helps out performance a little on very warm days. It also helps warm start conditions.xc8j said:So the electric heaters don't shut off the coolant? Talk to me about coolant shut offs! Jay
